Hackintosh Guide - Catalina / Big Sur / Monterey on Mobos Series 100, 200, 300, 400 and 500 with OpenCore Bootloader
[ref]madgario[/ref], DSDT.aml.zip
[ref]madgario[/ref], need read a manual for it and remember, is a newborn project :smoke:
Good morning MaLdOn. Lorenzo, from France ;). I hope you're doing fine my friend.
I am trying to install Mojave via open core, with your files, but at the boot the computer gets stuck after some seconds... I put you a pic of the moment when it blocks...
IMG_5030.pdf
[ref]Lorenzoo[/ref], try update all kexts
[ref]hbiieb95[/ref], ur config is very wrong, use Olarila clover folder for chipset 100/200/300 with fakecpuid for ur processor if need, reboot and extract new send_me
Good night MaLdOn. So I just tried with all kexts updated, and still the same, it get stuck, not at the same time but not far... I edited the config.plist, and it is totally empty, maybe it is a part of the problem, no ? I join you a pic and my efi folder.
Thanks in advance,
IMG_5038.pdf
EFI.zip
[ref]Lorenzoo[/ref], i don't have any haswell here for tests
Sorry, my mistake, I didn't precise my config: gigabyte B360M-ds3h/i3-8300/RX480 Nitro. The Haswell computer is relaxing..
Thanks again,
[ref]Lorenzoo[/ref], send me original dsdt
[ref]Lorenzoo[/ref], check if work
[ref]haitrvn[/ref], u can try
u don't need any ssdt, have all into dsdt
Hi Maldon,
I have created a config.plist for OC using the manual. I'm pretty sure everything is as it should be per the guide. After OC launches and shows the picker, choosing any Mac partition (Mojave or Catalina) just freezes at the OC picker screen (does not show any attempt at launching the Mac OS).
Any help is greatly appreciated.
OCEFI.zip
[ref]Lorenzoo[/ref], the problem is oc, this bootloader need many improvements for run one real good hack
Added in 1 minute 19 seconds:
[ref]septicshock[/ref], i need read manual for update efi from first post, many work here, i'll try check it
