[Request] DSDT for ALC882 audio codec for Asus P5W DH Deluxe
Would like to request the ALC882 DSDT patch for Asus P5W DH Deluxe
Tried the ALC883 patch and no luck.
Successfully installed SL 10.6.8 by iBoot 3.1.1 + multishit 3.7.2 with DSDT.aml extracted and patched by DSDT Editor.
Attached is the DSDT.aml extracted and patched for my Asus P5W DH Deluxe.
At the moment, I use WoodyHDA kext (which is AppleHDA v1.8.7f1) and HDAEnabler.kext from matemago (which is v1.0.0d1).
By the way, I have tried several version of AppleHDA.kext for Asus P5W DH Deluxe.
v1.7.4a1 matemago version --- working
v1.7.9a4 --- not working
v1.8.7f1 woodyhda version --- working
v1.9.9f12 --- not working
v2.0.5 from 10.6.8 --- not working
Thanks a lot.
DSDT_Asus P5W DH Deluxe.aml.zip
CPU= Core 2 Duo E6600
RAM= 4GB
Mobo = Asus P5W DH Deluxe
Audio= Realtek ALC882
Gfx= ATI 6670
Look the Info.plist file of HDAEnabler.kext for the properties it injects.
Thanks for showing a way to explore the kext, but it is beyond my skill to hack into kext and extract useful information. (Though I can successfully open package contents and read the info.plist.
Sincerely wish you or Maldon or other can make up the DSDT patch for ALC882 codec.
Attached is the HDAEnabler.kext by matemago.
HDAEnabler.kext.zip
<key>HDAProperties</key>
<dict>
   <key>PinConfigurations</key>
   <data></data>
   <key>built-in</key>
   <data>AA==</data>
   <key>layout-id</key>
   <data>DAAAAA==</data>
</dict>
It's the default HDEF + built-in
into method label _DSM parent_adr 0x001B0000 remove_entry;
into device name_adr 0x001B0000 insert
begin
{\n
   Store (Package ()\n
       {\n
               "built-in", \n
               Buffer (One)\n
               {\n
                   0x00\n
               }, \n
               "layout-id", \n
               Buffer (0x04)\n
               {\n
                   0x0C, 0x00, 0x00, 0x00\n
               }, \n
               "PinConfigurations", \n
               Buffer (Zero) {}\n
       }, Local0)\n
   Return (Local0)\n
end
If there isn't a device with _ADR = 0x001B0000 in your DSDT, apply the HDEF patch first.
