Issues MSI MPG Z390 Gaming Pro Carbon 64GB
System:
MSI MPG Z390 Gaming Pro Carbon AC
Intel I9-9900K
64GB DDR4 3200
EVGA 1080Ti FTW3
Getting error of Couldn't allocate runtime area
Using: Olarila CLOVER.SERIES.100.200.300 EFI (High Sierra)
I have tried OsxAptioFix2Drv-free2000
and a few other suggestions I had found on my own.
Has anyone gotten this board to work?
Image is a bit blurry,but.
<IMGUR id="pLv1O1a"><a href=https://i.imgur.com/pLv1O1a.jpg' alt='IMGUR>'>
post one full dump
--Run_Me
RunMe.app
[ref]luser01[/ref], disable intelhd graphics and vt-d in bios/uefi and go to install
[ref]luser01[/ref], no idea
try create other usb stick bootable
[ref]luser01[/ref], is not good, use it only if other solution don't work
replace full efi
EFI.zip
put it in ur desktop
https://Olarila.com/files/Utils/RepairPermissions.zip
run repair.command inside folder and reboot
if restart/shutdown don't work, use both files instead aptiomemoryfix
Arquivo Comprimido.zip
No go with either of those.
The solution I found came from https://nickwoodhams.com/x99-hackintosh-osxaptiofixdrv-allocaterelocblock-error-update/
Which references a clover ticket https://sourceforge.net/p/cloverefiboot/tickets/125/?limit=1000
The last post basically says some of us are out of luck
https://sourceforge.net/p/cloverefiboot/tickets/125/#b844
I was thinking that opencore might solve the issue, but I couldn't get that to work either.
[ref]luser01[/ref], use my full efi with drivers above if don't work in ur case, my patches solve it in 99%, in ur case not ;)
oc don't solve it
Yes, I used you full EFI and tried the files from Arquivo Comprimido.zip.
I am up and running now with the files I sent you. I should have gotten a gigabyte board :/
Thank for your help;
[ref]luser01[/ref], the problem is a nvram, just use other uefi driver for work
