hackintosh with two gc alpine ridge HELP!
I need to know if I can put two alpine ride cards on a z370 or z390 board because I need 4 thuberbolt 3 ports for my connections. please help!!!. :frantics
[ref]refruta[/ref], why not?
hi maldon because each card has a thbc-header cable connector and on the board there is only one port by default.
Have you ever installed two alpine cards?
i want put in Z390 AORUS MASTER .
thanks.
--------------------------IDEA-----------------------------
Did it occur to me something could connect devices in a chain? I could put two hard drives in a tb3 port with the adapter from tb3 to tb2 and connect two mac monitors in the other port also with its adapter from tb3 to tb2 is it correct?
----------------- another problem :(----------------------------
Now I'm having another problem. I have another device with a Z370 AORUS Gaming 5 board and an alpine ridge but only 1 port is working on any idea of that ??? :( the other port does not recognize neither hard disk nor monitor
thanks for the help
