Hello everyone! I'm try to install mac os on my pc it has a gtx 1060 6gb and intel core i5 8500...i used high sierra Olarila image...when i try to install nvidia web driver(i tried different versions) the package installer says it doesn't support my version of high sierra...im tried to update my s.o. from apple store but it cant update...when it restart for update dont do anything and reboot the s.o...how can i do? Sorry for my bad english i'm italian.
thanks very much for the answers :) .
thanks for the answer...i want update high sierra not nvidia web driver...because the version of high sierra which is in Olarila image doesn't have a nvidia web driver compatible...
Added in 8 minutes 53 seconds:
im tryed to install web driver by the file that you passed me but when i reboot high sierra after installation i see the full hd resolution etc but it blocks and alternates with black screen...obviously if i boot without nvidia web driver it works perfectly...i hope you understand me. if you want i post here in the topic the video with the issue. :)
[ref]maxwar[/ref], video work? u have acceleration?
no video doesn't work...i can record the video with my smartphone to show you the issue...
