[HELP] GB Card Thunderbolt ALPINE RIDGE + GB H370 HD3
Hi Friend!!
I hava a GB Card Thunderbolt ALPINE RIDGE + GB H370 HD3.
I activated in Windows 10 the GB Card Thunderbolt ALPINE RIDGE, but in OSX Mojave 10,14,5 dosent works (not connect or disable).
Where is the problem ?¿
Thanks!!
[ref]cachiputi[/ref], try it, connect device before power hackintosh
[ref]cachiputi[/ref], first u need update bios/uefi to last version, after need update thunderbolt software via windows, after it start work on macos
Hi MaLd0n !!
Now in Windows 10 its OK.
But in OSX not driver load.
<IMGUR id="HIHoEIY"><a href=https://i.imgur.com/HIHoEIY.png' alt='IMGUR>'>
<IMGUR id="QWSlL3M"><a href=https://i.imgur.com/QWSlL3M.png' alt='IMGUR>'>
Only Works in OSX USB 3.1 but not TH. The same connector.
Any idea?
Obrigado!!
[ref]cachiputi[/ref], hot plug don't work native, u need connect device before power hack
Hi MaLd0n !!
Is it possible for the hot plug to work, with a DSDT created by you, for this Hackintosh in particular?
Thank you!!
[ref]cachiputi[/ref], extract one send_me
--Run_Me
RunMe.app
[ref]SilverbackAudio[/ref], u can check a KGP work about it, work good with single ssdt
