Can someonr help me solve several acpi errors?
2019-05-31 18:22:41.149113+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) ACPI Error:
2019-05-31 18:22:41.149114+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) ACPI Error:
2019-05-31 18:22:41.149116+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) [_SB_.PCI0.RP05.PXSX]
2019-05-31 18:22:41.149117+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) [_SB_.PCI0.RP05.PXSX]
2019-05-31 18:22:41.149119+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) Namespace lookup failure, AE_NOT_FOUND
2019-05-31 18:22:41.149829+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) ACPI Error:
2019-05-31 18:22:41.149830+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) ACPI Error:
2019-05-31 18:22:41.149832+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) [_SB_.PCI0.RP09.PXSX]
2019-05-31 18:22:41.149854+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) ACPI Error:
2019-05-31 18:22:41.149855+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) ACPI Error:
2019-05-31 18:22:41.149857+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) Method parse/execution failed
2019-05-31 18:22:41.149859+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) [\_SB.PCI0.RP08.PXSX] (Node ffffff8034021e40)
2019-05-31 18:22:41.149860+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) [\_SB.PCI0.RP08.PXSX] (Node ffffff8034021e40)
2019-05-31 18:22:41.149862+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) , AE_NOT_FOUND
2019-05-31 18:22:41.178052+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) ACPI Error:
2019-05-31 18:22:41.178054+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) Cannot assign type [Device] to [integer] (must be type Int/Str/Buf)
2019-05-31 18:22:41.178055+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) Cannot assign type [Device] to [integer] (must be type Int/Str/Buf)
2019-05-31 18:22:41.178058+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) (20160930/exstoren-203)
2019-05-31 18:22:41.178086+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) ACPI Error:
2019-05-31 18:22:41.178087+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) ACPI Error:
2019-05-31 18:22:41.178088+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) Method parse/execution failed
2019-05-31 18:22:41.178089+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) Method parse/execution failed
2019-05-31 18:22:41.178091+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) [\_SB.PCI0.RP15._INI] (Node ffffff8034046c30)
Send me Mojave.zip
[ref]mathewgx[/ref], first u need apply all patches in ssdt inside dsdt, ssdt is not a clean way, need many renames etc and some good patches don't work
@MaLd0n,
I prefer ssdt hotpatch because I don't need to make any changes after bios update.
Do you have any idea what these acpi errors mean ?
[ref]mathewgx[/ref], if u have a stable bios/uefi version, u don't need update every time
a full dsdt edited = 2 minutes
u need try delete entries in dsdt for solve acpi warnings and errors
[ref]mathewgx[/ref], DSDT.aml.zip
change GFX0 to IGPU
47465830
49475055
change HDAS to HDEF
48444153
48444546
change HECI to IMEI
48454349
494d4549
change SAT0 to SATA
53415430
53415441
Wow !!!
Will try as soon as possible.
Just a question though. I have read that with latest whatevergreen.kext renames like GFX0 to IGPU , HDAS to HDEF and HECI to IMEI are not suggested anymore. Do you agree?
[ref]mathewgx[/ref], we need it for renames devices in ssdts oem, same devices in ssdt and dsdt, clover rename in all tables
