hi MaLd0n, my dell xps go to sleep and wake fine but light is missing with my clover folder, if use folder olarilla for CHIPSET SERIES 5, 6, 7, 8, 9 I have light on sleep but missing bluetooth ,sound and brightness. check me and support please, regardsCLOVER.zip
dell xps13 9360
core i7
Intel HD620
-ram 8 gb ddr3
-hard disk da 256 gb SDD
[ref]vrondena[/ref], check "Useful Links" in my sig
[ref]vrondena[/ref], audio, video, battery, dsdt, etc
Send me MacBook-di-vr.station.zipsorry but ... we all get crazy with kext, patches and tests of all types clover folders with various files and then ..... one try the generic chipset clover folder without dsdt-ssdt-with a config.plist minimal and without smbios and ......... everything works equally video, audio, brightness and hear hear, something I wanted so much, the flicker light on the power button when I put it to sleep.military.was missing the bloutooth and the trackpad the rest worked everything. I put the kext for the bloutooth and it is activated also with the trackpad but when I tried the sleep again the light was not anymore. sleep works regularly but without flicker. I am attaching the terminal sleep report. where the flashing light worked is the "maintenance sleep" part> darkwake to fullwake.
I also send the send-me that I generated. if someone gives me the solution to have the light I would be very grateful
Schermata 2019-07-24 alle 12.01.27.zip
dell xps13 9360
core i7
Intel HD620
-ram 8 gb ddr3
[ref]vrondena[/ref], DSDT.aml.zip
u need a pulse light in power button at sleep state?
[ref]vrondena[/ref], u need read chipset datasheet and acpi specs
check here
https://www.insanelymac.com/forum/topic/320798-pulsing-power-led-while-sleeping/
sorry MaLd0n but my DSDT does not contain the method SLED,LEDS and LEDW and chipset datasheet and acpi spec.not knowing where to find, I ask if you can kindly correct mine DSDT.please
dell xps13 9360
core i7
Intel HD620
-ram 8 gb ddr3
[ref]vrondena[/ref], Use DSDT above, have a good patches, essentials, etc
but pulse led is not easy and some cases don't work, is very specific for chipsets, need read datasheets
I apologize again, but at the first start with the clover folder (without dsdt) to create the sende-me I then put it to sleep and the light worked then somewhere and somehow you can make the problem is that I don't know how to identify how.
dell xps13 9360
core i7
Intel HD620
-ram 8 gb ddr3
