l3ekoot Posted May 23, 2019 Posted May 23, 2019 Hi, I am newbie, i am using tool SSDT_Automator genarate ssdt but i have error. https://imgur.com/a/mgnCskk Please help me path ssdt. System infor. Main: B360M d2v CPU: i3 9100f RAM: 8gb VGA rx 470. send_me.zip
Administrators MaLd0n Posted May 23, 2019 Administrators Posted May 23, 2019 [ref]l3ekoot[/ref], u just need my dsdt, don't need ssdt -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
l3ekoot Posted May 24, 2019 Author Posted May 24, 2019 [ref]l3ekoot[/ref], u just need my dsdt, don't need ssdt If i don't use ssdt then systems any problem?
Administrators MaLd0n Posted May 24, 2019 Administrators Posted May 24, 2019 [ref]l3ekoot[/ref], no, u don't need SSDT, need only my DSDT -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
l3ekoot Posted May 25, 2019 Author Posted May 25, 2019 [ref]l3ekoot[/ref], no, u don't need SSDT, need only my DSDT Thanks for support. After i using dsdt of you then. - I am shutdown ok but light keyboard do not off. - I am using windows then shutdown normal, keyboard turn off. => This is problem?.
Administrators MaLd0n Posted May 25, 2019 Administrators Posted May 25, 2019 [ref]l3ekoot[/ref], check if have ERP option in bios/uefi -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
l3ekoot Posted May 25, 2019 Author Posted May 25, 2019 [ref]l3ekoot[/ref], check if have ERP option in bios/uefi I have confirm bios setting ErP is disable. But after turn off macOS then light keyboard keep open. I have switch boot to windows then after shutdown windows then turn light keyboard turn off normal. I think macOS is problem?.
Administrators MaLd0n Posted May 25, 2019 Administrators Posted May 25, 2019 [ref]l3ekoot[/ref], is a bios problem, erp option enable or disable solve it in some case, try -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
