Hi
I'm newbie for hackintosh. I've just installed with Mojave Olarila image and i found some problems. Unable to shutdown or restart and panic screen is appear. I attached a file from RunMe.app
My computer
CPU - Intel Core i7 8700
M/B - GIGABYTE H370 HD3
VGA - XFX RX580 8GB
Ram - DDR4 16GB Kington
I apologize for my weak english.
Thank You.
Send me i7-8700ks-iMac.zip
VGA - XFX RX580 8GB
xfx cards are no good an you runme files are not attached
:superman:superman
--Run_Me
RunMe.app
you clover folder is not in the run me app have you followed the guide an placed in the new clover folder an reinstalled the clover efi bootloader?
your recommended clover folder https://Olarila.com/files/Clover.Folder/CLOVER.NOTEBOOKS.100.200.300.zip
:superman:superman
[ref]radeon55x2[/ref], DSDT.aml.zip
