[Guide] Native USB Fix for Desktops - No Injector/Kext Required - SkyLake+
9 minutes ago, thief_fighter said:
I'll buy a usb bluetooth and hope airdrop works
and work? i think no
need a pci card with native support
check about that
check about that
Is there anyway to change this to true?
https://www.dropbox.com/s/jvl00j7xm2rnsj1/Screen Shot 2020-07-19 at 02.01.38.png?dl=0
Currently it is false and which mean MacOS doesn't recognize it as internal card.
Edit: Seems like plug this to USB3 port will solve it, I need to sacrifice the front USB ports
https://www.aliexpress.com/item/32956605450.html?spm=a2g14.12057483.0.0.36f22b5ayg0F3q
or Patch DSDT with _PRW 0x0 method. But it will make you can't wake by usb device. Only power button can.
Can you help me patch DSDT?
Edited by thief_fighter
new sendme
4 hours ago, thief_fighter said:
Thanks for your help!
enjoy
  • Thanks 1
16 hours ago, MaLd0n said:
enjoy
I had an old bluetooth USB lying around, plugged it in and now it has handoff/airdrop. I don't even have to set it to 255, it just worked. Sometime the solution is very simple :(
is a realtek card reader pci, dont have native solution
--About Credits for this method--
The source for the methods is the motherboard ACPI is not mald, geng, etc. Is just duplicated one OEM method(GUPC in this case), renamed(We need device name) and applyed connectors type(Credits is not for us. We just rename and duplicate devices) . All credits for it is for Piker Alpha HERE and not for Italian peopleThis method of mapping has existed for many, many years and is not my credit or gengik or texem or 5t33z0.
The resume is: We stole method GUPC from intel and apply the Piker way ofc.?
I read about this on Pikers Blog alongtime ago. But YOUR TUTORIAL HERE is very easy to understand and well laid out. I had absolutely no problem understanding everything you are talking about here. Awsome Guide and Thank You very much my friend!
Also: Up to this point The way I have had to approach this without mapping was to add inside the DSDT the values Taken from IOReg under EHC1 EHC2 XHC1 etc inside the ports of each. Such as Below this was on My DELL XPS L521X IvyBridge and Thats what i was having to do to avoid USB Mapping.
I am most certainly going to utilize the method That You have described here "GUPC TUPC UPC and implement it into all of my hacks as it simplifies things universally wheras my method above i cant say that it will work on all because it will not. Your method will however work on everything "So Props Maldon to You" Its Intels Shit but so what--You pieced it together and put it into this tutorisl for everyone who is interested to be able to use it so credits should go to You!.
Anyway I included the actual custom stripped DSDT that i wrote out for that particular Laptop below
DSDT.aml.zip  Just as example of what i was referring to.
		Scope (PCI0)
            Device (EHC1)
                Name (_ADR, 0x001D0000)  // _ADR: Address
                Name (_PRW, Package (0x02)  // _PRW: Power Resources for Wake
                    0x0D,
                    0x04
                Method (_DSM, 4, NotSerialized)  // _DSM: Device-Specific Method
                    If ((Arg2 == Zero))
                        Return (Buffer (One)
                             0x03                                             // .
                    Return (Package (0x0A)
                        "device-id",
                        Buffer (0x04)
                             0x26, 0x1E, 0x00, 0x00                           // -...
                        "kUSBSleepPowerSupply",
                        0x13EC,
                        "kUSBSleepPortCurrentLimit",
                        0x0834,
                        "kUSBWakePowerSupply",
                        0x13EC,
                        "kUSBWakePortCurrentLimit",
                        0x0834
            Device (EHC2)
                Name (_ADR, 0x001A0000)  // _ADR: Address
                    0x0D,
                    0x04
                    If ((Arg2 == Zero))
                             0x03                                             // .
                        "device-id",
                        Buffer (0x04)
                             0x2D, 0x1E, 0x00, 0x00                           // &...
                        0x13EC,
                        0x0834,
                        0x13EC,
                        0x0834
		Scope (PCI0)
            Device (XHC)
                Name (_ADR, 0x00140000)  // _ADR: Address
                OperationRegion (XPRT, PCI_Config, 0x74, 0x6C)
                Field (XPRT, DWordAcc, NoLock, Preserve)
                    Offset (0x01),
                    PMEE,   1,
                        ,   6,
                    PMES,   1,
                    Offset (0x5C),
                    PR2,    32,
                    PR2M,   32,
                    PR3,    32,
                    PR3M,   32
                    0x0D,
                    0x04
                    If ((Arg2 == Zero))
                             0x03                                             // .
                    Local0 = Package (0x0B)
                            "device-id",
                            Buffer (0x04)
                                 0x31, 0x1E, 0x00, 0x00                           // 1...
                            "AAPL,current-available",
                            0x0834,
                            "AAPL,current-extra",
                            0x0A8C,
                            "AAPL,current-extra-in-sleep",
                            0x0A8C,
                            "AAPL,max-port-current-in-sleep",
                            0x0834,
                            Buffer (One)
                                 0x00                                             // .
                    Return (Local0)
                Device (RHUB)
                    Name (_ADR, Zero)  // _ADR: Address
                    Device (HS01)
                        Name (_ADR, One)  // _ADR: Address
                            If ((Arg2 == Zero))
                                     0x03                                             // .
                                0x0834,
                                0x0834,
                                "kUSBHostPortPropertyOffset",
                                Zero,
                                "kUSBCurrentSleepAllocation",
                                Zero,
                                "kUSBBusCurrentSleepAllocation",
                                Zero
                    Device (HS02)
                        Name (_ADR, 0x02)  // _ADR: Address
                            If ((Arg2 == Zero))
                                     0x03                                             // .
                                0x0834,
                                0x0834,
                                Zero,
                                Zero,
                                Zero
                    Device (HS03)
                        Name (_ADR, 0x03)  // _ADR: Address
                            If ((Arg2 == Zero))
                                     0x03                                             // .
                                0x0834,
                                0x0834,
                                Zero,
                                Zero,
                                Zero
                    Device (HS04)
                        Name (_ADR, 0x04)  // _ADR: Address
                            If ((Arg2 == Zero))
                                     0x03                                             // .
                                0x0834,
                                0x0834,
                                Zero,
                                Zero,
                                Zero
                    Device (SS01)
                        Name (_ADR, 0x05)  // _ADR: Address
                            If ((Arg2 == Zero))
                                     0x03                                             // .
                                0x0834,
                                0x0834,
                                0x04,
                                Zero,
                                "kUSBBusCurrentAllocation",
                                0x96
                    Device (SS02)
                        Name (_ADR, 0x06)  // _ADR: Address
                            If ((Arg2 == Zero))
                                     0x03                                             // .
                                0x0834,
                                0x0834,
                                0x04,
                                Zero,
                                0x96
                    Device (SS03)
                        Name (_ADR, 0x07)  // _ADR: Address
                            If ((Arg2 == Zero))
                                     0x03                                             // .
                                0x0834,
                                0x0834,
                                0x04,
                                Zero,
                                0x96
                    Device (SS04)
                        Name (_ADR, 0x08)  // _ADR: Address
                            If ((Arg2 == Zero))
                                     0x03                                             // .
                                0x0834,
                                0x0834,
                                0x04,
                                Zero,
                                0x96
Ever wondered why some Hackintoshes run flawlessly while others struggle? What if the key lies in understanding the motherboard ACPI methods and how to effectively customize them? Let's dive into the essential tweaks that could elevate your Hackintosh experience!
In the realm of Hackintosh, true expertise is invaluable. While many rely on cookie-cutter solutions, those who understand the intricacies of Vanilla setups can unlock the full potential of their systems. So, is it time to reconsider the ethics of using premade SSDTs, or are we simply enabling a culture of shortcuts that compromises our craft?
