[Guide] Native USB Fix for Desktops - No Injector/Kext Required - SkyLake+
3 hours ago, snake881 said:
Thanks, was because I forgot delete Usbinjectall.kext, now it's working!! Thanks ?
@MaLd0n sorry for bother you, but I don't know why the speed of transfer get extremely low, here I'm testing a Kingston 3.0 USB 5Gbps, but there is no correlation with the speed that actually I'm getting.
Test speed transfer file.png.zip
Check if appears 5gb
6 hours ago, snake881 said:
Yes, that appears when I connect the USB 3.0, when it’s 2.0 480 Mbps
test other usb stick
I did that, and here are the results:
USB 2.0 Back panel
USB 2.0 Front panel
USB 3.0 Back Panel
The USB:
Edited by snake881
I put the images wrong
USB 2.0 Back panel
USB 2.0 Front panel
USB 3.0 Back Panel
The USB:
@MaLd0n sorry for bother you again, I was trying to solve my problem, but I did not figure it out.
checking my log files shows me that
(IOUSBFamily) <IOUSBFamily`AppleUSBInterface::updateProperties()> USBMSC Identifier (non-unique): 9207113553251816710 0x1320 0x1908 0x200, 2
2020-05-19 21:19:06.143991-0400  localhost kernel[0]: AppleUSBInterface: family specific matching fails
2020-05-19 21:19:06.144011-0400  localhost kernel[0]: AppleUSBInterface: family specific matching fails
Even I tried with Hackintool patching method, but stills is very slow my USB ports.
use one good usb stick ?
@MaLd0n Can you help me with USB patch?
This is the kext generated from Hackintool, however when I applied this script it still show HS01->HS12, not sure if I applied the script correctly.
Also my bluetooth internal port is shown as USB2.0 Hub, which mean it can't be set as internal. (please check the attached picture). Is there anyway to fix it?
USBPorts.kext.zip Screen Shot 2020-07-18 at 09.46.09.png.zip
check ioreg, device xhc
In XHC I see only SS01, SS02 and SS05 and I tried to plug in my HDD to all of the ports but it can't be recognized.
Do you know how can I fix the internal bluetooth USB? Only the hub is configured to be internal.
Edited by thief_fighter
what ur mobo?
10 hours ago, thief_fighter said:
ASRock B460M Pro4
just set hs01 to internal. generate new with hackintool
btw, u don't need any ssdt with my dsdt, is a full solution
Yes, I've disabled all other ssdt and only have your ssdt/dsdt in the config.
I set hs01 to internal and generate new with hackintool. However my computer still couldn't sleep and USB3 device is not recognized.
use ur previous kext usb and edit plist inside kext, set hs01 to internal - 0xFF - 255
however computer still couldn't sleep. It only sleep when I disable HS01 completely.
bluetooth is connect via usb cable in mobo?
14 minutes ago, thief_fighter said:
Yes, you can see it here
if set to internal don't solve. idk
  • Sad 1
