Ghoys Posted October 20, 2019 Posted October 20, 2019 do i have to install usbinjectall.kext and the xhci-unsupported.kext ? after using hackintool patch?
Administrators MaLd0n Posted October 20, 2019 Author Administrators Posted October 20, 2019 [ref]Ghoys[/ref], after create injector, remove usbinjectall.kext and xhci-unsupported.kext -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Smooth Posted November 6, 2019 Posted November 6, 2019 Hey MaLd0n thx for the tip can your please patch my ssdt? i have a try on it but it fail Chipset: z170 thx again SSDT-2-xh_rvp08.aml.zip
Administrators MaLd0n Posted November 6, 2019 Author Administrators Posted November 6, 2019 [ref]Smooth[/ref], SSDT-2-xh_rvp08.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Smooth Posted November 6, 2019 Posted November 6, 2019 Hey MaLd0n txh for quick reply but that file doesn't work no usb devices found i used your SSDT-6-A M I.aml yust for a test here all usb ports worked but i get these error in system log No Local Variables are initialized for method [_UPC] thx
Administrators MaLd0n Posted November 6, 2019 Author Administrators Posted November 6, 2019 [ref]Smooth[/ref], ssdt6 is from my mobo, not for u -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Smooth Posted November 6, 2019 Posted November 6, 2019 i know but it work with mine (only some error) like No Local Variables are initialized for method [_UPC] and namespace error the SSDT-2-xh_rvp08.aml doesn't can you proof it please
Administrators MaLd0n Posted November 6, 2019 Author Administrators Posted November 6, 2019 [ref]Smooth[/ref], ssdt 2 looks good, idk what not work -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Smooth Posted November 6, 2019 Posted November 6, 2019 With your SSDT-2-xh_rvp08.aml i testet every port HSxx and SSxx but nothing will happen on plug in. Testet with usb2 stick and usb3 stick.
Administrators MaLd0n Posted November 6, 2019 Author Administrators Posted November 6, 2019 [ref]Smooth[/ref], generate one injector with hackintool -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Smooth Posted November 6, 2019 Posted November 6, 2019 on top to the SSDT-2-xh_rvp08.aml? hackintool shows this https://www.dropbox.com/s/4haiivjdd03366e/usb.png?dl=0
Administrators MaLd0n Posted November 6, 2019 Author Administrators Posted November 6, 2019 [ref]Smooth[/ref], change all connectors to usb3 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Smooth Posted November 7, 2019 Posted November 7, 2019 done but change nothing now i have these files in the ACPI/patched folder SSDT-2-xh_rvp08.aml SSDT-EC.aml SSDT-UIAC.aml SSDT-USBX.aml SSDT.aml (for CPU) and no kext for usb. thx
Administrators MaLd0n Posted November 7, 2019 Author Administrators Posted November 7, 2019 [ref]Smooth[/ref], if u use my dsdt u don't need any ssdt 3party, -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
rockhard Posted November 19, 2019 Posted November 19, 2019 (edited) Hey MaLd0n Can you help patching my SSDT, I tried everything and doesn't load.... Here is my original ssdt , edited ssdt and a map of the ports. With you SSDT -6- AMI.aml the usb works , with mine it doesn't .... SSDT-3-xh_kbl_s-original.aml.zip SSDT-3-xh_kbl_s-edited.aml.zip Edited November 19, 2019 by Guest
rockhard Posted November 19, 2019 Posted November 19, 2019 the usb map Screen Shot 2019-11-19 at 7.08.53 PM.zip
Administrators MaLd0n Posted November 19, 2019 Author Administrators Posted November 19, 2019 [ref]rockhard[/ref], SSDT-3-xh_kbl_s.aml.zip u need use a correct ssdt name for clover override correct table -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
rockhard Posted November 19, 2019 Posted November 19, 2019 What name ? My original usb SSDT table is called "xh_kbl_s". Should I drop the original tables in clover? This is my original DSDT/SSDT saved from Clover boot with F4. origin.zip
Administrators MaLd0n Posted November 19, 2019 Author Administrators Posted November 19, 2019 [ref]rockhard[/ref], extract with run_me.app and check ACPI folder in the root of the dump -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
rockhard Posted November 19, 2019 Posted November 19, 2019 Thx , figured out what to do. Working good with OpenCore, without usbinjectall.kext, UIAC-SSDT.
Administrators MaLd0n Posted November 19, 2019 Author Administrators Posted November 19, 2019 [ref]rockhard[/ref], -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Bryann2802 Posted January 12, 2020 Posted January 12, 2020 Hi MaLd0n, Please help me with my EFI, don´t give function the USB ports, send u my EFI. I need the SSDTplease My Hackintosh have a Core i7 6700 and Motherboard Gigabyte Z170 Mx gaming 5 my EFi: https://drive.google.com/open?id=1aPSlcYMSO9n2II0Zk5nMwwGVY26cRXjx I wait your helful. Thanks.
Administrators MaLd0n Posted January 12, 2020 Author Administrators Posted January 12, 2020 Hi MaLd0n use usb port limit remove patch + one usb injector created by hackintool -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
telepati Posted January 18, 2020 Posted January 18, 2020 @MaLd0n little confused while disabling the port; My USB Port Capabilities looks different than your example. While disabling the port I know we are using 'Zero'. Please look at the picture and tell me am I right? Should I delete H7CN in the GUPC and write the 'Zero' value there? Edit: I deleted and test it. It's working. Thank you MaLd0n.
esata Posted January 21, 2020 Posted January 21, 2020 ain .. tem uma versão para nub? ain ... has a version for nub? ASUS G20CB-B21 Gaming Desktop | H170-P/G20CB/DP_MB. | Intel Core i7-6700 3.4GHz | NVIDIA GTX 1070 8GB | (2x8GB) 16GB DDR4 SDRAM | Realtek ALC887 | Realtek 8821AE | BLUETOOTH: ? | SSD: 128GB KINGSTON SHFS37A120G | HDD: 1TB TOSHIBA DT01ACA100 | ADAPTER 180W 19.5V 3P(5.5PIH) / ADAPTER 230W 19.5V 3P(7.4PHI) | G20AJ CPU FAN ASSY / G20BM THE MOD ASSY
