[Guide] Native USB Fix for Desktops - No Injector/Kext Required - SkyLake+
[ref]swede420[/ref], extract one send_me with last files
[ref]swede420[/ref], all ports is load now, if don't work, use usbinjectall
For som reason even if I use usbinjectall only USB3 devices will load on the port that I though not working.
[ref]swede420[/ref], if u use usbinjectall, just use kext + usb port limit patch, remove ssdt
same, thanks. I am tired of this so I will drop it as is. Thankyou
Hi Maldon, can u give more details of how to do it? How do i check OEM SSDT's? Wich tool i have to use to edit, etc... Im a newbie in patching this stuffs, and im slowing learning about.
[ref]janjao[/ref], se vc usar kexts e o patch vai funcionar bem, isso é o método vanila sem as kexts de terceiros
[ref]mathewgx[/ref], with opencore u need drop oem table and add edited oem table, Acpi/Block/TableLength
my laptop usb type c is not under HSxx or SSxx, looking to IOReg its under psxs, is that ok?
I'm using USBInjectAll + SSDT-UIAC
Hack Pro: Asus Strix Z590i, i9-11900K, RX 6900 XT, 1TB Samsung QVO SSD, RAM 16GB Corsair RGB @3200Mhz (Big Sur) OC
Hackbook Pro: (MSI GE63 Raider RGB) i7-8750H, Intel UHD 630, GTX1070 8GB(disabled), 16GB RAM @2666Mhz (Big Sur) OC
[ref]RandomTech7[/ref], extract one send_me
extract one send_me
sorry I forget to mention is showing as usb 3.1 under "about this mac"
here is sendme::
Send me MacBook-Pro.zip
[ref]RandomTech7[/ref], remove SSDT-PNLF.aml, SSDT-UIAC.aml and SSDT-USBX.aml
Remove USBINJECTALL too
check with hackintool, usb tab
RandomTech7, remove SSDT-PNLF.aml, SSDT-UIAC.aml and SSDT-USBX.aml
thank you for making it all-in-one DSDT solution
it still not showing under xhc14 in IOReg, its under psxs, not showing in Hackintool usb tab as well.
but its working with 5gb speed so its ok for me.
5 photos attached here to clarify even better.
https://imgur.com/a/O7xd3NX#wgY4nx6
[ref]RandomTech7[/ref], looks good, usb-c in ur case work native, don't need nothing, we just remove unnecessary files :cap
now I got it, thank you
My all USB's stopped working. I sent to my RX560 to service and I start to use HD630 added framebuffer for HDMI to devices/properties for Z390M Gaming. I can boot but my all USB's stopped working. I cleaned cache and NVRAM with MacOptimizer but when I boot no USB anymore.
What could have happened?
