Administrators MaLd0n Posted June 21, 2019 Author Administrators Posted June 21, 2019 [ref]telepati[/ref], checked here and hs10 is not used port, enable port in ssdt -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
telepati Posted June 21, 2019 Posted June 21, 2019 [ref]telepati[/ref], checked here and hs10 is not used port, enable port in ssdt Sorry, but what do you mean? Just like you said I enabled port in ssdt. Please look at the pictures isn't it right? I also tried both connectors type but nothing changed.
Administrators MaLd0n Posted June 22, 2019 Author Administrators Posted June 22, 2019 [ref]telepati[/ref], extract one send_me -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
telepati Posted June 22, 2019 Posted June 22, 2019 [ref]telepati[/ref], extract one send_me Here is my send me files. Send me iMac-2.zip
Administrators MaLd0n Posted June 23, 2019 Author Administrators Posted June 23, 2019 [ref]telepati[/ref], hs10 is full load https://i.imgur.com/pSuRDGh.png' alt='IMGUR>'> sound like a bug system repair permission, rebuild cache -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
telepati Posted June 23, 2019 Posted June 23, 2019 [ref]MaLd0n[/ref], I made a couple of changes in BIOS enabled XHC and 4G then repair permission and rebuild the cache, Now everything works. The picture you released it says AppleUSB20InternalHub now it says AppleUSB20Hub. But I will make a test with default BIOS settings. Cause I want to be sure this is BIOS related issue or not. Edit: Test it with Default BIOS settings not changed. Everything still works. Thats mean repairs and rebuild cache fixed my problem. Thank you.
aldebaran Posted June 28, 2019 Posted June 28, 2019 MaLd0n, I have different SSDT-5-AMI.aml file. So what should I do to get fixed SSDT file? Here is my USB SSDT file. Thank you for any help. Regards, Aldebaran SSDT-5-A M I.aml.zip
Administrators MaLd0n Posted June 28, 2019 Author Administrators Posted June 28, 2019 [ref]aldebaran[/ref], just create devices and check all _UPC -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
aldebaran Posted July 2, 2019 Posted July 2, 2019 MaLd0n, What do you mean by creating device? Regards, Aldebaran
Administrators MaLd0n Posted July 2, 2019 Author Administrators Posted July 2, 2019 [ref]aldebaran[/ref], is a methods for identify ports Method (MALD for example -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
swede420 Posted July 12, 2019 Posted July 12, 2019 Hi Madl0n! This is my SSDT for usb, I want do do native USB patches but I am confused about all those DP01,DP02, exec... Cn you please help me? Thanks in advance. SSDT-3-xh_rvp10.aml.zip
onemanosx Posted July 12, 2019 Posted July 12, 2019 [ref]MaLd0n[/ref], My OEM does not contain UMAP and I have difficulty enabling the ports. Even adding UMAP didnt help either. Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
Administrators MaLd0n Posted July 12, 2019 Author Administrators Posted July 12, 2019 [ref]swede420[/ref], u need test Added in 2 minutes 3 seconds: [ref]onemanosx[/ref], have many variations in my notebook for example 0xff enable and Zero disable https://i.imgur.com/V1QEL7C.png' alt='IMGUR>'> -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
swede420 Posted July 12, 2019 Posted July 12, 2019 [ref]swede420[/ref], u need test I have bild this one but when I boot with it no USB att all. Can you please take a look? SSDT-3-xh_rvp10-E.aml.zip
Administrators MaLd0n Posted July 12, 2019 Author Administrators Posted July 12, 2019 [ref]swede420[/ref], u have a many ports disable, many many, check all and put One -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
swede420 Posted July 12, 2019 Posted July 12, 2019 [ref]swede420[/ref], u have a many ports disable, many many, check all and put One How do I check? Is there a utility for it?
Administrators MaLd0n Posted July 12, 2019 Author Administrators Posted July 12, 2019 [ref]swede420[/ref], read first post, u need check all _UPC -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
swede420 Posted July 12, 2019 Posted July 12, 2019 Now I thought I got it right but one port does not work. Tried to enable the disabled ports one by one but it did not work. What can I do? Send me Alijans-iMac.zip SSDT-3-xh_rvp10-e2.aml.zip
Administrators MaLd0n Posted July 13, 2019 Author Administrators Posted July 13, 2019 [ref]swede420[/ref], full efi folder, replace, reboot and check if work, don't change nothing, just replace full efi EFI.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
swede420 Posted July 13, 2019 Posted July 13, 2019 [ref]swede420[/ref], full efi folder, replace, reboot and check if work, don't change nothing, just replace full efi EFI.zip Thankyou, but it did not work. The same USB port still don't work, it is working until boot though.
