[Guide] Native USB Fix for Desktops - No Injector/Kext Required - SkyLake+
[ref]piyushrawal[/ref], DSDT.aml.zip
now, just change One to Zero if u need disable
[ref]MaLd0n[/ref], am I to use it alongside SSDT-4-xh_rvp08.aml or just the DSDT?
I am sorry for being a total noob.
And thanks a ton for your help. :)
[ref]piyushrawal[/ref], use both files ssdt and dsdt, only it with my EFI folder
For laptops (at least for my skylake laptop), it is also worth to know that native _UPC or _PLD is within DSDT itself. Similarly, like how Maldon had described all we need to do is replace zero to one and define usb type in the scope of UUPC and UPLD as per my example.
Hope this helps for some of us.
https://imgur.com/TY6U1wM
Donate
Gitter Chat
MSI B360 Gaming Arctic
:guitar
[ref]Canela[/ref], SSDT-6-A M I.aml.zip
Can I also use this? Our motherboard is the same. Should I make any changes? If I can use this, can or should I remove these kexts and SSDT;
SSDT-UIAC.aml
XHCI-unsupported.kext
USBInjectAll.kext
[ref]telepati[/ref], yes, use ssdt with usb patch limit port for raise one port more, this mobo have a 16 usb ports
[ref]MaLd0n[/ref], following your guide I have edited your SSDT to change some ports. I do not use the HS09, so I have a total of 15 ports ... does that mean I can erase the USB Port Limit Patches?
<IMGUR id="A2vFCHL"><a href=https://i.imgur.com/A2vFCHL.png' alt='IMGUR>'>
[ref]Canela[/ref], if u use only 15 ports, yes. Don't need usb limit port
Internal USB 2.0 didn't work. No Bluetooth hardware anymore.
These are my all 15 ports;
CLOVER 2.zip
[ref]telepati[/ref], u need change things, i have many devices usb like bt
Thanks to the warning. I used 15 ports and removed patch limit. My HS10 is the Internal and using Bluetooth connection. Just like you said on the first page I use GUPC (One) and enabled it. But still doesn't work, still says no Bluetooth hardware. I am totally losing my Bluetooth. Could you please tell me what am I doing wrong?
SSDT-USB.aml.zip
[ref]telepati[/ref], u try other like 0x03...
What do you mean by that? Is MALD instead of GUPC for internal HS10?
Edit:
I tried all connectors made all HSxx to MALD, TUPC, GUPC but nothing changes no internal USB and No Bluetooth connection. I think no native USB for me.
SSDT-USB.aml.zip
[ref]telepati[/ref], test port with one device usb2 or usb 3
