[Guide] Native USB Fix for Desktops - No Injector/Kext Required - SkyLake+
--About Credits for this method--
The source for the methods is the motherboard ACPI is not mald, geng, etc. Is just duplicated one OEM method(GUPC in this case), renamed(We need device name) and applyed connectors type(Credits is not for us. We just renamed and duplicated devices) . All credits for it is for Piker Alpha HERE and not for Italian peopleThis method of mapping has existed for many, many years and is not our credit.
The resume is: We stole method GUPC from intel and apply the Piker way ofc.?
-All credits to Piker-Alpha
Here
https://pikeralpha.wordpress.com/2016/07/13/simple-skylake-usb-fix-no-kexts-required
and here
https://pikeralpha.wordpress.com/2016/11/10/two-port-usb-3-1-gen-ii-pci-express-card/
1- Check OEM SSDT about USBs, in my case is SSDT-6-A M I.aml, i'm using a Z390 mobo
2- Create Methods into SSDT OEM inside Scope _SB.PCI0.XHC.RHUB, Internal and USB 2 is native, just create USB 3, USB-C
-In some cases some ports have a Method _STA = Zero, change to 0x0F to enable
We just need duplicate Methods (GUPC for example) native from our ACPI table and Inject values
Connector types in the ACPI specification(pages 524 and 525)
https://uefi.org/sites/default/files/resources/ACPI_6.0.pdf
0xFF - internal - GUPC
Zero - USB 2 - TUPC
0x03 - USB 3 - MALD
0x09 - USB-C - MAL0 (Same HSxx/SSxx in both orientations, then it has an internal switch)
0x0A - USB-C - MAL1 (Different HSxx/SSxx in each orientation, then it has no switch)
-Example
GUPC and TUPC is a native Methods
Quote
Method (GUPC, 1, Serialized)
Name (PCKG, Package (0x04)
Zero,
0xFF,
Zero,
Zero
PCKG [Zero] = Arg0
Return (PCKG) /* \_SB_.PCI0.XHC_.RHUB.GUPC.PCKG */
Method (TUPC, 1, Serialized)
One,
Zero,
Zero,
Zero
PCKG [Zero] = Arg0
Return (PCKG) /* \_SB_.PCI0.XHC_.RHUB.TUPC.PCKG */
Method (MALD, 1, Serialized)
Zero,
0x03,
Zero,
Zero
PCKG [Zero] = Arg0
Return (PCKG) /* \_SB_.PCI0.XHC_.RHUB.MALD.PCKG */
Method (MAL0, 1, Serialized)
Zero,
0x09,
Zero,
Zero
PCKG [Zero] = Arg0
Return (PCKG) /* \_SB_.PCI0.XHC_.RHUB.MAL0.PCKG */
Method (MAL1, 1, Serialized)
Zero,
0x0A,
Zero,
Zero
PCKG [Zero] = Arg0
Return (PCKG) /* \_SB_.PCI0.XHC_.RHUB.MAL1.PCKG */
3- Enable or Disable USB ports
-Check example TUPC
Look at Method _UPC - USB Port Capabilities
Enable = One
Disable = Zero
Example
Quote
Scope (\_SB.PCI0.XHC.RHUB.HS01)
Method (_UPC, 0, NotSerialized) // _UPC: USB Port Capabilities
If ((H1TC == Zero))
If (((UMAP & One) == One))
Return (TUPC (One))
Else
Return (GUPC (Zero))
Else
Return (\_SB.UBTC.RUCC (H1CR, One))
If you need identify your USB ports like USB-C for example, change TUPC/GUPC to MAL0
Quote
Scope (\_SB.PCI0.XHC.RHUB.SS01)
If ((H1TC == Zero))
Return (MAL0 (One))
Else
Else
Zero - USB 2 - TUPC
0x03 - USB 3 - MALD
-USB 2 PORTS inside USB 3 BUS, just Inject USB 3
-My SSDT with edits
SSDT-6-A M I.aml.zip
-Use a Diff Merge to compare files
-Original
ORIGINAL.txt.zip
-Edited
EDITED.txt.zip
-Download Diff Merge
https://sourcegear.com/diffmerge/downloads.php#
Excellent guide [ref]MaLd0n[/ref], awesome!!
Bit by bit we will understanding more about ACPI patching, thank you.
But one doubt, I need to keep the USB Injection at Clover? E.g: Devices > USB > Inject/FixOwnership/HighCurrent
Thanks & Regards
[ref]Allan[/ref], u can use it in clover without problem
[ref]mathewgx[/ref], check if work
SSDT-2-xh_OEMBD.aml.zip
the image have all ur real ports?
[ref]mathewgx[/ref], ;)
[ref]vinpo[/ref], all
[ref]piyushrawal[/ref], dont need usbinjectall and XHCI-unsupported.kext
use ssdt with usb patch limit and u don't need more
SSDT-xh.aml.zip
https://Olarila.com/forum/viewtopic.php?f=62&t=6539
if u need change connectors, check inside all _upc and change
Zero - USB 2 - TUPC
0x03 - USB 3 - MALD
0x09 - USB-C - MAL0
0x0A - USB-C - MAL1
btw, SSDT-xh is a native name or u renamed it? use a native name and clover replace a correct table, i never test with rename
SSDT-xh.aml.zip
Zero - USB 2 - TUPC
0x03 - USB 3 - MALD
0x09 - USB-C - MAL0
0x0A - USB-C - MAL1
It's working with limit patch. But I am unable to disable USB ports to get it under 15 limit by setting Return (MALD (One)) to Return (MALD (Zero)). It has no effect.
And yes, renaming was a bad idea. It doesn't work if renamed.
[ref]piyushrawal[/ref], remove ssdt uiac
[ref]piyushrawal[/ref], replace full EFI, reboot and extract new send_me, don't change nothing
EFI.zip
[ref]piyushrawal[/ref], run my app for full dump
--Run_Me
RunMe.app
[ref]piyushrawal[/ref], DSDT.aml.zip
now, just change One to Zero if u need disable
