0xMe Posted May 19, 2019 Share Posted May 19, 2019 I have followed the following guide step by step. https://Olarila.com/forum/viewtopic.php?f=51&t=6718 USB boots perfectly. after that I chose my SSD to install the Mojave on. It starts the download then it stuck at 2 minutes giving me this logs. APFS issue. I have tried both formatting MAC os journaled and also APFS format both stuck at the same time with the same error message. Attached Photos. My Build is: CPU : i7-8700k MoBo: Gigabyte B360 Gaming 3 WiFi Graphics: AMD radeon Rx 580 I disabled Vt-d. I am not sure what is my mistake or my build is not compatible. HELP PLEASE.! ver.rar Link to comment Share on other sites More sharing options...
erroruser Posted May 19, 2019 Share Posted May 19, 2019 try these combos Aptiofixdrv + emuvariable 2. Aptiofix2drv +emuvariable 3. Aptiofix3drv+emuvariable if you do not have access with mac to use clover config follow through here https://Olarila.com/forum/viewtopic.php?f=80&t=8919 AMD Ryzen 7 3700X, MSI MPG X570 Gaming Plus, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, Sapphire rx 5700 XT, fractal celcius s36 HP Notebook - 15-ay028ca (Touch), 16 GB 2133 MHz DDR4, Intel HD Graphics 520 1536 MB Asus z97-c i5, i5 4460, 32 GB 1648 MHz DDR3, Radeon RX 560 4096 MB, Corsair H75 Liquid CPU Cooler Link to comment Share on other sites More sharing options...
0xMe Posted May 25, 2019 Author Share Posted May 25, 2019 try these combos Aptiofixdrv + emuvariable 2. Aptiofix2drv +emuvariable 3. Aptiofix3drv+emuvariable if you do not have access with mac to use clover config follow through here https://Olarila.com/forum/viewtopic.php?f=80&t=8919 Did not work Link to comment Share on other sites More sharing options...
erroruser Posted May 25, 2019 Share Posted May 25, 2019 check to make sure these are correct an your bios is updated Load Optimized Defaults If your CPU supports VT-d, disable it If your system has CFG-Lock, disable it If your system has Secure Boot Mode, disable it Set OS Type to Other OS If your system has IO SerialPort, disable it Set XHCI Handoff to Enabled Disable CSM AMD Ryzen 7 3700X, MSI MPG X570 Gaming Plus, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, Sapphire rx 5700 XT, fractal celcius s36 HP Notebook - 15-ay028ca (Touch), 16 GB 2133 MHz DDR4, Intel HD Graphics 520 1536 MB Asus z97-c i5, i5 4460, 32 GB 1648 MHz DDR3, Radeon RX 560 4096 MB, Corsair H75 Liquid CPU Cooler Link to comment Share on other sites More sharing options...
