mosun1 Posted May 2, 2019 Share Posted May 2, 2019 (edited) After repairing my motherboard, I can't enter macOS. I think this is due to problems caused by the manufacturer's upgrade to the latest BIOS after repair. I tried to downgrade the BIOS version number but it didn't help. Downgrade the BIOS version number but the ME version number has not changed. I added the relevant patch of ASRock's new BIOS to config.plist, and it has no effect. I really have no other way, please help me. I got the new BIOS DSDT file by pressing F4 on the clover interface, but I can't enter macOS, I can't run Run_Me.app, I can't provide you with complete information. CLOVER.zip PS: CPU:i7 8700k MB:Asrock Z370 Extreme4 GPU: UHD630+R580 8g Edited May 2, 2019 by Guest Link to comment Share on other sites More sharing options...
erroruser Posted May 2, 2019 Share Posted May 2, 2019 [ref]mosun1[/ref], have you looked at the setting as when a bios is updated it can revert some settings AMD Ryzen 7 3700X, MSI MPG X570 Gaming Plus, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, Sapphire rx 5700 XT, fractal celcius s36 HP Notebook - 15-ay028ca (Touch), 16 GB 2133 MHz DDR4, Intel HD Graphics 520 1536 MB Asus z97-c i5, i5 4460, 32 GB 1648 MHz DDR3, Radeon RX 560 4096 MB, Corsair H75 Liquid CPU Cooler Link to comment Share on other sites More sharing options...
mosun1 Posted May 2, 2019 Author Share Posted May 2, 2019 [ref]mosun1[/ref], have you looked at the setting as when a bios is updated it can revert some settings Yes, I will reconfigure the BIOS settings after I downgrade the BIOS.But still the same mistake, can't enter macOS Link to comment Share on other sites More sharing options...
erroruser Posted May 3, 2019 Share Posted May 3, 2019 [ref]mosun1[/ref], try with this clover also you were missing information in it an possibly your drivers were wrong CLOVER.zip AMD Ryzen 7 3700X, MSI MPG X570 Gaming Plus, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, Sapphire rx 5700 XT, fractal celcius s36 HP Notebook - 15-ay028ca (Touch), 16 GB 2133 MHz DDR4, Intel HD Graphics 520 1536 MB Asus z97-c i5, i5 4460, 32 GB 1648 MHz DDR3, Radeon RX 560 4096 MB, Corsair H75 Liquid CPU Cooler Link to comment Share on other sites More sharing options...
mosun1 Posted May 4, 2019 Author Share Posted May 4, 2019 [ref]mosun1[/ref], try with this clover also you were missing information in it an possibly your drivers were wrong Just tested, still did not solve the problem, the same error code Link to comment Share on other sites More sharing options...
erroruser Posted May 4, 2019 Share Posted May 4, 2019 [ref]mosun1[/ref], an you use these settings Load Optimized Defaults If your CPU supports VT-d, disable it If your system has CFG-Lock, disable it If your system has Secure Boot Mode, disable it Set OS Type to Other OS If your system has IO SerialPort, disable it Set XHCI Handoff to Enabled disable csm AMD Ryzen 7 3700X, MSI MPG X570 Gaming Plus, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, Sapphire rx 5700 XT, fractal celcius s36 HP Notebook - 15-ay028ca (Touch), 16 GB 2133 MHz DDR4, Intel HD Graphics 520 1536 MB Asus z97-c i5, i5 4460, 32 GB 1648 MHz DDR3, Radeon RX 560 4096 MB, Corsair H75 Liquid CPU Cooler Link to comment Share on other sites More sharing options...
