Help me turn off the CPU Thermal and Power limit
Hello,
My asus laptop has Thermal and power throttling control in BIOS, which can be disabled by using throttlestop (in Windows) and check "disable memory mapped turbo power limits" . Anyone can help me disable this annoying limits on Mojave ? My 8550u can run at 40w on windows but in Macos it can only runs at 6w when temp reached 60*C . really bad.
Send me macs-MacBook-Pro.zip
[ref]wanttolove[/ref], some improvements
u need disable turbo boost?
I need to disable the OEM throttling and make the turbo boost run at its max as long as it can. I think ASUS make this CPU throttling at 60*c and 15W max , I just want to disable this limit. I will try your modified DSDT today. One more thing, do you know how to make my Keyboard backlit lighting work? thank you for your help
