2 hours ago, Cuzco said:
AZAL para HDEF
não precisa disso
tenta com a voodoohda por enquanto
Deu certo a voodoo - sé funciona os autofalantes mas não o Headphone, mas dá pra trabalhar enquanto aparece a solução definitva proALC274
Could someone help me with alc662 audio? My motherboard is a TA-MBB75 and whenever I tried to make a hackintosh I had problems with audio, sometimes network and video, but the audio was always off. There was an old snow leopard image that worked 100% but I would now like to use newer OSs.
check first post. ur audio codec have support
Hi! I've tried this tutorial and other ones, but I still facing issues on my ALC892 with Big Sur. HDMI audio is OK, but the onboard audio is not recognized. I've tried all of layout-id, but no success.
Configs:
Motherboard: Killsre X99
CPU: Xeon E5 2678v3
GPU: RX 470 4GB
Audio: ALC892
Send me iMac-Pro-de-Murilo.zip
Edited by mrX
SP/Brazil :help
last kexts version?
9 hours ago, MaLd0n said:
last kexts version?
Yes sir, both updated.
Lilu on 1.5.1
AppleALC on 1.5.8
Looking at AppleALC changelog, I found it
  • Added C610/X99 Audio Controller r1 support by masking to 8ca0
  • Added C610/X99 Audio Controller r2 support by masking to 8ca0
What should be mask to 8ca0?
Edited by mrX
SP/Brazil :help
11 hours ago, Bruno Graciano Alves Carneiro said:
Funcionou com sucesso, muito obrigado.
Flw!
check manufacturer page
Lilu on 1.5.1
AppleALC on 1.5.8
Conseguiu solucionar? tenho a mesma placa e apenas o audio onboard não funciona. Também tentei todo Layout ID, sem sucesso
Abri mão do áudio HDMI e passei a usar o VoodooHDA
SP/Brazil :help
if dont support ur codec u need create one layout
check applealc faq
Hi
I followed the procedure and even after putting in all the IDs of my ACL662 sound card and it didn't work.
I'm using Big Sur 11.3.1
Would anyone have any other suggestions?
9 minutes ago, renatonls said:
Hi
Have you copied the kext to its folder in EFI and added in the plist in boot-arg     alcid = 7     ?
Thanks for your help
I copied the file to VoodooHDA.kext the Kexts folder
According to the model of my xxx board I tested the parameters in the ACLID 5,7,11,12,13,15,16,17,18 and 66
Even with all these tests the problem persists,
I'm sending the RunME result in case someone needs to analyze some other details
https://we.tl/t-A4zkTA3Svx
