8 hours ago, dawilliams660 said:
I found the drivers for it on the windows side, is there any way I can find out what codec it is form that?
u need check applealc project
ok....where can I find this?.....I would love to get this laptop to work......this and the WiFi not working...everything else is working
ASUS PRIME 450M-A, AMD Ryzen 7 2700x, Nvidia GT730 4gb, 16gb ram
https://www.olarila.com/topic/6074-guide-easy-audio-solution-with-applealc-clover-and-opencore/
check docs in acidanthera for hdmi audio
I don't know how to inject audio layout to config.plist, when I changed the argument key in boot dictionary, no sounds work also the VGA malfunction, I don't know what to do my laptop is Lenovo z5070, and there is no information about audio codec in Hackintool, but I used the hexa code, and I find that it is ALC282.
clover in boot tab, arguments
opencore in nvram tab
alcid=1 for example
alcid=1 for example
it causes the vga to disfunction, this is the DPCIManager sees the audio card, and the Hackintool doesn't provide any info
images
Well I have tried all layout available for my CX20751/2 but still no audio devices are detected  ,
I have used VoodooHDA and sound is working but HDMI Audio is not working.
What should I do now ?
if don't work use voodoohda
6 hours ago, AmazingHarsh said:
How to get HDMI Audio ?
this patch dont solve?
https://www.olarila.com/topic/6420-guide-mobile-intel-hd-graphics-skylake/
On 9/8/2020 at 2:07 AM, MaLd0n said:
u need dev id into hdas/hdef device
Hey Maldon how to use this can you please help as I try this I got sound but no mic working should I delete fake pccid
hey
last applealc work without it. dont need
Não sei se alguém já teve essa placa aqui mas a ALC274 é um fenômeno. Ela só tem 1 layout (21) - Tudo parece funcionar ( o ícone de som aparece, voce pode aumentar o volume, ele faz o switch pro headphones, o microfone grava) mas o som não sai ! Nem nas caixas de som nem nos Headphones. Andei vendo alguns forums com esse mesmo problema. Tem gente tentando fazer manualmente o layout, outros aconselharam usar um patch de AZAL para HDEF mas tambem não funcionou.
