9 hours ago, 胡哥 said:
It says No audio codec detected!!no audio codecs found!
Be sure to have AppleHDA or VoodooHDA somewere!
install lilu and applealc, inject alcid=3 and start follow tutorial
but it didn't work, and hackintool didn't say anything.
check via windows or manufacturer page
Anyone has been successful with AD2000b and Olarila Vanilla Mojave with Lilu and AppleLC ?
Video card + Network card + Skullcandy USB headset are working fine but I can't seem to get my P6T Deluxe v2 soundboard to be detected either with layout ID 5 or 7 in Clover even with MaLd0n's patched DSDT file (obrigado).
Is it normal that hackintool shows 99 as a layout ID?
(blue flagged files are to allow my RAID drives to be detected, grey to make my integrated Yukon Ethernet work).
free picture hosting
Edited by mozbius
Detailed pictures of Clover Configurator
u try last kexts version and alcid=5 or other supported layout for ur audio codec
Thank you for your support  MaLd0n!
After some further investigation here's what works with my Mojave P6T Deluxe v2 (AD2000b) setup (I will retest with layout id 5 again just in case)...
KEXTS Latest Lilu & AppleLC
CLOVER CONFIGURATOR: ACPI: change HDAS to HDEF
CLOVER CONFIGURATOR: Devices: Layout 7, ResetHDA,
upload image to internet
AND deleting HDAEnabler kext
I also removed LegacyAppleYukon2 since it didn't turn on my Marvel Yukon network card on my motherboard (IONetworkingFamily did )Audio-Kexts.png
By the way my Rosewill RDCR-11004 - Data Hub is working too (when something is connected in it during boot sequence) which is awesome.
Quick question : Can P6T motherboard install Catalina?
Muito obrigado.
IONetworkingFamily.kext.zip SATA-RAID.zip
Edited by mozbius
hdas to hdef is skylake+, u dont need it
u can try catalina. i never use lga775 or 1366 in cata
  • Thanks 1
Hello, I have an icelake laptop with alc256 codec... I tried all of the layout id, but none of them worked...I was able to see outputs, i can't hear sounds... I tried to make a custom one (i don't know if it was correct) but i see the outputs, but i can't hear sound... Tried with codeccommander or without, nothing changed...
Can you help me?
My Desktop: CPU: i7-7700K, MOBO: Asus Strix Z270F, GPU: Powercolor RX5700, RAM: 16GB 3200mhz
Laptop: Model: Asus S512J-EJ051T CPU: i7-1065g7 GPU: Intel g7 / Nvidia MX330 RAM: 8GB 2666mhz
2 hours ago, MaLd0n said:
Hi, i checked the folder, i noticed that the only differences are the FakePCIID, but if i try them, they won't get loaded and i get no sound...
u need dev id into hdas/hdef device
Quote
"device-id", Buffer () {0x70, 0xA1, 0x00, 0x00}
Thanks a lot! It resolved my problems!
Enjoy!
On 4/18/2019 at 3:01 PM, MaLd0n said:
-Donations with PayPal
https://tinyurl.com/r2bvzm7
I have a problem in the undetected audio I have tried with Hackintoshtool and Read me.app but it is not detected. I tried running DCPImanager on the audio device 0x80861E20 and Sub Device 0x10280591, but the Code Name column did not appear. I've copied and pasted AppleALC.kext and Lilu.Kext in EFI / Clover / Kext / Other
Help me
This is the result I run Read me.app
DSDT.aml
20 hours ago, IGosa Bagus Yuniarta said:
I have a problem
check manufacturer site
1 hour ago, Giancarlo Laredo Agüero said:
Hi, my sound card is not showing up in Hackintool. I'm using Olarila Catalina + Ryzen 7 + RX570 + B450M chipset + ALC892
applealc+lilu?
2 hours ago, dawilliams660 said:
tried this and still no audio
check if ur audio codec have support
