[ref]GoLFiiToOo[/ref], just use same patch video from other config
[ref]GoLFiiToOo[/ref], u just need use only video patch from old config ;)
[ref]MaLd0n[/ref],
Where do I do this part of your instruction?
-Chipset 100/200/300 Just Rename
HDAS to HDEF
48444153
48444546
My First Hackintosh: GA-Z390 Gaming M/Intel Core i5 9400F/32GB G.Skill 3600/MSI RX6600XT
[ref]wastedbrain[/ref], applealc rename it for u
add a alcid=1
[ref]Shahzad[/ref], try others layout first
@MAldon- I have tried all the layout. when I record voice memos, I am able to hear very faint noise from it , it seems like the gain of internal microphone is too low. Is there any way that it can be increased? And also, will you be able to help in multitouch gestures for ELAN1010 touchpad?
[ref]Shahzad[/ref], check useful links in my sig
I can't get the audio to work on my hackintosh
check what ur audio codec and follow instructions from first post
2snpfFS"><a href=https://imgur.com/a/2snpfFS' alt='IMGUR>'> i already did this apple alc compatible with realtek alc 233 I followed a lot of tutorial and I still have no sound I just reinstalled catalina
no détected my device audio
use applealc + lilu, reboot and check with dpcimanager or hackintool
I tried all layouts and so but all it does it load applealc and nothing for codec and no devices show up in audiopreferencies.
Seems it doesnt load codec. The computer is Lenovo thinkstation S30 with C602J chipset and Xeon 1620V2, AMD Vega56 and ALC662 V3 soundcard. I can see some values inserted in ioreg but still not loading codec.
clover-files
http://s000.tinyupload.com/index.php?file_id=45712889393805286198
codecdump is also attached.
CodecDump-ALC662v3.zip
I tried all layouts
use it with Olarila folder, ur config is very wrong
Used X79 Olarila Clover. Added the DSDT and rebooted a few times. Seems computer runs a bit smoother but Audio still not recognised so I tried all the alcid=x as bootargument. But still no audio device on any.
Used this list: https://github.com/acidanthera/AppleALC/tree/master/Resources/ALC662
Btw, computer complains about power to USB-port even when an USB-stick is put in. If I put an USB-hub in between it doesn't. How can I fix this?
http://s000.tinyupload.com/?file_id=45529456253735692911
audio is just layout id, if don't work u can edit/create applealc layout for ur case, check github for it
about usb, use it
remove usbinjectall.kext
