[ref]longcoming[/ref], i see many changes :mrgreen: is about ioreg, errors, warnings in logs, etc, fix all now ;)
thx for test
[ref]Zarach[/ref], é só usar a applealc+lilu e rodar o run_me.app, ele vai te dizer qual o codec, um dos dumps é sobre áudio
Troquei a AppleAlc por uma mais recente.
Tá funcionando.
Obrigado!
HahAhAH
Hi Guys, can anyone please help....
I have a Dell Inspiron 13-5378 with MacOS Catalina installed on it - all works fine apart from the audio.
I have the latest AppleALC & Lilu kexts located in Kexts/other (nowhere else)
I have checked using DPCIManager and it states that I have Realtek ALC225 I have checked in Apple ALC Master folder and it states I should have 3 Layouts available - 28, 30 & 33
I have tried all 3 (using Clover Configurator) but none are working, I just don't know what else to do!
Can anyone please help
[ref]aide199[/ref], u can try a applehdapatcher
Olá Madlon, tentei todos os layouts possíveis pra minha placa e nenhum funcionou, s[o usando voodoo msm, mas não ta legal o som.
Notebook Dell G7 7588
ALC 256
vlw
Added in 1 minute 24 seconds:
coloquei as Kexts noa pasta, tu certinho e nada
ALC 256
vlw
[ref]titoneto[/ref], alc256 funciona bem com a applealc, se preciso for use codeccommander tb
How do I know if have to apply patches on my device?
[ref]vikesyy[/ref], what patches?
I have tried All Pin Configuration for my Codec, but still no luckk with Sound!
Added in 22 seconds:
[ref]MaLd0n[/ref], My Codec is ALC236, I have tried layouts but it doesn't work with Apple ALC. Do I have to install it on S/L/E?
[ref]vikesyy[/ref], no, work inside clover/kexts/other
check applehdapatcher
Hello, I have been testing and I have not managed to make the audio work, even following the tutorial perfectly.
I think my problem is in the config.plist, since before I used to work the audio in a vanilla way.
Could you check my config.plist to see what is happening?
I had to use this config.plist to make the hd4400 graphics work
thanks friend :)
runme http://s000.tinyupload.com/index.php?file_id=65250266115735847394
[ref]GoLFiiToOo[/ref], in ur case just need applealc+layout id and use codeccommander too
Hello, I have reloaded my original clover with the dsdt you made me and I have perfect audio again.
But now I have the other problem that I solved with the other config.plist I was using.
I get graphics 4400 4MB
Hackintool does not work for me :(
