[ref]MaLd0n[/ref], nevermind fixed it by reinstalling clover
Added in 10 minutes 30 seconds:
I followed all the steps but it's still not working :|
[ref]Clawric[/ref], u need try all layouts, inject, save, reboot, test, every time
[ref]Clawric[/ref], use voodoohda or patch applehda
i can't find the alc id through dpci manager or runme please help me when i see in RunMe or DPCI Manager it says
Vendor : INTEL DP/HDMI
Codec : 0x80862807
what should i do
[ref]mody44ever[/ref], check ur notebook specs, check manufacturer site
hi [ref]MaLd0n[/ref],
i have alc235 and already try to install latest applealc.kext and lilu.kext on L/E, and inject layout id = 28 to config.plist, but the sound still not work. when i check the ioreg file, why alc-layout-id always 7? even if i already inject other layout id, but on ioreg still not change. here is my send_me file
Send me LONEXTs-MacBook-Pro.zip
[ref]aryaone[/ref], <IMGUR id="dQdniCV"><a href=https://i.imgur.com/dQdniCV.png' alt='IMGUR>'>
[ref]aryaone[/ref], remove it, Inject ur layout id in option above, Audio/Inject
[ref]Naskall[/ref], applealc
[ref]ahmedgamal09[/ref], applehdapatcher, check tread
Mald0n,
I use the same Z390 M gaming as yours, ALC892 but when I tried layout 7 like you did, no sound at all. I tried all other layout but they didn't work either.
Audio works via bluetooth connection though. Help! :(
[ref]astroboyvn88[/ref], work fine, 1, 7 and others
just use hdas to hdef, layout id, applealc+lilu
