Hello dears,
Please I have issue after installation of macOS Ventura on my Lenovo with the below specifications :
Machine Model: Z50-70 Laptop (Lenovo) - Type 80E7
Motherboard CPU full model: Intel(R) Core(TM) i7-4510U CPU @ 2.00GHz   2.60 GHz
SSD/HDD and capacity: 2 hard drives SSD: will use for Mac 256Gb, HDD for Windows 1Tb.
Audi Codec: Conexant CX20751/2 HD Audio
Graphic: Intel HD4400 , and Opencore EFI.
What I Did?
1-I tried to use some guide for post installation for audio issue in this link & link using Lilu and AppleALC but it was not helpful even all layout ID I tried but still not worked.
2-I tried AppleHDA patcher using this guide but patcher app did not work on macOS Ventura. --> AppleHDA vanilla patched kext worked in High Sierra (10.13) using clover.
3-I tried VoodooHDA kext , at first I disabled AppleALC in config.plist and install VoodooHDA but it does not worked, --> VoodooHDA kext worked in Mojave using clover.
Note:
1- I tried to use clover boot loader but unfortunately my laptop chips Haswell  not supported and could not find EFi folder so I used OpenCore EFI folder also Olarila image.
2-Audio codec can not be detected by any tools, and already my audio codec Conexant CX20751/2 HD Audio supported by AppleALC.
3-Run.me App output from this link: https://we.tl/t-4jSJ7NS1Bn , I could not attach since size was 10.1MB.
please really need to find a solution for this hackintosh to make audio work.
Thank you
I have ALC892 with codec 4, the microphone is enabled and working but the sound does not work, it recognizes it but does not make any sound
I have ALC892 and use codec 4, the internal microphone works but not the internal speaker, it does not make any sound but its recognized
Dear support,
in my case no audio device nothing to see with hackintosh tool,
Also i did it Apple Alc kext inside the kext folder on EFI folder
On 8/27/2023 at 12:41 AM, AndreMaculan said:
ASUS ZENBOOK UX433FA
VENTURA
ALC294
TRIED ALL LAYOUT, THE DRIVER IS RECOGNIZER BUT NO SOUND OUTPUT.
ONLY THE JACK MAKE SOUND NOISES.
HELP?
Did you fix the problem?
Mine has the same codec but no sound with every LayoutID I tried
On 4/18/2019 at 3:01 PM, MaLd0n said:
Easy Audio Solution with AppleAlc for your Hackintosh
Updated tutorial HERE
1- Use AppleAlc.kext and Lilu.kext in Clover/kexts/other(preferred) or Library/Extensions
Download AppleAlc HERE
Download Lilu HERE
2- You need check what your audio codec
You can use a Hackintool, Manufacturer Page or Run_me.app for check it(stay with AppleAlc load)
-Hackintool
Download Hackintool HERE
-Manufacturer Page
-Run_Me.app
Download Run_Me.app HERE
Let's Start
1- Go to AppleAlc GitHub page HERE
2- Go to "Clone or download/Download ZIP"
3- Extract file and go to Resources folder
4- Check what layout-ids you can use for your audio codec(in my case is ALC892)
I have many options for my audio codec
5- Clover Solution
Open config.plist with one good plist editor, go to Boot/Arguments and add alcid=xx (xx is layout-id for your audio codec)
6- OpenCore Solution
Open config.plist with one good plist editor, go to NVRAM/Add/boot-args and add alcid=xx (xx is layout-id for your audio codec)
-Credits and thanks to the old and new people in the community who developed patches, kexts and bootloaders!
How do I compile if I make any changes to this file in the resources folder, so that it "returns" to AppleALC.kext?
