Administrators MaLd0n Posted January 12, 2022 Author Administrators Posted January 12, 2022 10 hours ago, tsaipen said: I've followed the tutorial, but it doesn't work in some cases need extra things like irqs solution -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Indiana SxS Posted February 5, 2022 Posted February 5, 2022 My issue is i don't see the sound card. I am using a Haswell efi. Please see zip with screenshot Screen Shot 2022-02-04 at 4.45.20 PM.zip
Administrators MaLd0n Posted February 5, 2022 Author Administrators Posted February 5, 2022 check manufacturer page -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Indiana SxS Posted February 5, 2022 Posted February 5, 2022 (edited) It doesn't show on manufacturer's page. I have an HP Envy 15t-k000 On the manufacture page it shows realtek driver for windows to download but doesn't say anywhere what my card is my serial of the laptop is 5CD434879Q What should i do from here? 1 hour ago, MaLd0n said: check manufacturer page I put LInux Mint on a USB and booted it up and did a lspci -v and here is what it says and audio is working in this linux. 00:03.0 Audio device: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller (rev 06) Subsystem: Hewlett-Packard Company Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller Flags: bus master, fast devsel, latency 0, IRQ 35 Memory at b2610000 (64-bit, non-prefetchable) Capabilities: <access denied> Kernel driver in use: snd_hda_intel Kernel modules: snd_hda_intel 00:1b.0 Audio device: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller (rev 05) Subsystem: Hewlett-Packard Company 8 Series/C220 Series Chipset High Definition Audio Controller Flags: bus master, fast devsel, latency 0, IRQ 36 Memory at b2614000 (64-bit, non-prefetchable) Capabilities: <access denied> Kernel driver in use: snd_hda_intel Kernel modules: snd_hda_intel I tried another command on my linux usb and i think i got it. I used arecord -L and it returned ALC3241 as shown below. So armed with ALC3241 and the screenshot i provided earlier what do i do? mint@mint:~$ arecord -l **** List of CAPTURE Hardware Devices **** card 1: PCH [HDA Intel PCH], device 0: ALC3241 Analog [ALC3241 Analog] Subdevices: 1/1 Subdevice #0: subdevice #0 Edited February 5, 2022 by Indiana SxS cleanup paste
Indiana SxS Posted February 5, 2022 Posted February 5, 2022 ok so i am new to this. So tell me if im doing something wrong. I am using the haswell efi from the downloads section. in kexts it has applealc and lilu. i am using opencore. i see the following here? Realtek ALC290/ALC3241 layout 3, 4, 10, 15, 28 i go into opencore nvram i have tried to type in each layout above. -v alcid=15 watchdog=0 igfxonln=1 -no_compat_check i havent got audio. am i doing stuff wrong am i soppose t do something physically with files in kexts ? What am i missing? am i missing a step? Do i have to have AppleHda ? i didnt see that mentioned in this guide? if so how do i do that? thanks for anyones help.
laudou Posted July 20, 2022 Posted July 20, 2022 On 4/18/2019 at 2:38 PM, MaLd0n said: [ref]Sampath007[/ref], Thanks. Works ok with alcid=2
ameen Posted September 2, 2022 Posted September 2, 2022 My hackintosh huawei matebook d15 i5-10210u everything is working fine Except sound • Intel(R) Audio for displays device ids:INTELAUDIO\FUNC_01&VEN_8086&DEV_280B&SUBSYS_80860101&REV_1000INTELAUDIO\FUNC_01&VEN_8086&DEV_280B&SUBSYS_80860101• Intel Smart Sound - audio controller:PCI\VEN_8086&DEV_02C8&SUBSYS_1260152D&REV_00PCI\VEN_8086&DEV_02C8&SUBSYS_1260152DPCI\VEN_8086&DEV_02C8&CC_040100PCI\VEN_8086&DEV_02C8&CC_0401• ESAuDriver DeviceACPI\VEN_ESSX&DEV_8336&SUBSYS_152D1262ACPI\ESSX8336*ESSX8336 I think 8086 02c8 controller supported by applealce but real sound is Essx8336 codec sound it is not supported by apple alc yet It is i2c sound card Do you know about this essx8336 guide anywhere?
futureorkun Posted September 13, 2022 Posted September 13, 2022 I am attaching my system log. I tried many ways. But ALC274 layout ID:21.28.35.39 none of them output from the headphone. Do not offer VoodooHDA. Tried, doesn't work. I am attaching my site log and EFI. In addition, while the xhciportlimit is ticked in USB patching, the USBs become reactive when the device is turned on. In this case I can't patch. What can I do as a solution for this? EFI: https://easyupload.io/zmni3c 520-24ICB.zip
Administrators MaLd0n Posted September 13, 2022 Author Administrators Posted September 13, 2022 https://github.com/acidanthera/AppleALC/wiki/Adding-codec-support -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Osk Posted October 29, 2022 Posted October 29, 2022 (edited) hello, I downgrade cpu from ryzen 3600 to athlon 200GE and now I have ramdom stuttering audio. already try all the alcid numbers for my codec 1220A....any thoughts. Thanks. mobo asus b450-f, cpu athlon 200GE and gpu RX6600XT https://www.mediafire.com/file/ju94wd7hulrgxdr/Send_me_192.168.1.3.zip/file Edited October 29, 2022 by Osk
salim mohammed Posted November 23, 2022 Posted November 23, 2022 Where do you even copy and paste the layout ids files, will you copy them to your efi resources folder or where
Administrators MaLd0n Posted November 23, 2022 Author Administrators Posted November 23, 2022 u need add number on alcid=xx bootarg or inject via device properties -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
salim mohammed Posted November 23, 2022 Posted November 23, 2022 My Audio codec is ALC662 hash 4570 4th generation only audio is not working
Alexander Gutarev Posted December 16, 2022 Posted December 16, 2022 (edited) Hi, Why the volume control does not work? Sound Card: scarlet solo. Attach data and screenshot Thanks. Send me iMac-Pro.zip screen.zip config.plist.zip Edited December 16, 2022 by Alexander Gutarev
Administrators MaLd0n Posted December 17, 2022 Author Administrators Posted December 17, 2022 5 hours ago, Alexander Gutarev said: Why the volume control does not work? Sound Card: scarlet solo. this card don't use applealc, have a correct driver for that -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
futureorkun Posted December 25, 2022 Posted December 25, 2022 (edited) 13.09.2022 saat 10:54'te MaLd0n şunları söyledi: https://github.com/acidanthera/AppleALC/wiki/Adding-codec-support Man, this job is beyond impossible for me. Why don't you help? Edited December 25, 2022 by futureorkun
Deivison Souza Posted January 9, 2023 Posted January 9, 2023 .. Em 18/04/2019 às 15:01, MaLd0n disse: 1-Use AppleAlc.kext e Lilu.kext em Clover/kexts/other(preferencial) ou Biblioteca/Extensões Baixar AppleAlc https://tinyurl.com/y6vh5aqy Baixar Lilu https://tinyurl.com/ya657fxl 2-Você precisa verificar qual o seu codec de áudio Você pode usar um Hackintool, Página do Fabricante ou Run_me.app para verificá-lo (ficar com o carregamento AppleAlc) -Hackintool Baixar Hackintool https://tinyurl.com/yamzbgd6 -Página do fabricante -Run_Me.app Baixar Run_Me.app https://tinyurl.com/y9562hz7 Vamos começar 1-Ir para a página do AppleAlc GitHub https://tinyurl.com/yath7r42 2-Vá para "Clone ou download / Download ZIP" 3-Extraia o arquivo e vá para a pasta Recursos 4-Verifique quais layout-ids você pode usar para o seu codec de áudio (no meu caso é ALC892) Tenho muitas opções Solução 5-Trevo Abra config.plist com um bom editor de plist, você pode usar um Clover.app, vá para Boot/Arguments e adicione alcid=xx (xx é layout-id para o seu codec de áudio) Solução 6-OpenCore Abra config.plist com um bom editor de plist, vá para NVRAM / Adicionar / boot-args e adicione alcid = xx (xx é layout-id para o seu codec de áudio) -Créditos e agradecimentos às pessoas antigas e novas da comunidade que desenvolveram patches, kexts e bootloaders! Slice, Kabyl, usr-sse2, jadran, Blackosx, dmazar, STLVNUB, pcj, apianti, JrCs, pene, FrodoKenny, skoczy, ycr.ru, Oscar09, xsmile, SoThOr, RehabMan, Download-Fritz, Zenit432, cecekpawon, Intel, Apple, Oracle, Chameleon Team, crazybirdy, Mieze, Mirone, Oldnapalm, netkas, Elconiglio, artut-pt, ErmaC, Pavo, Toleda, Master Chief e família, bcc9, The King, PMheart, Sherlocks, Micky1979, vit9696, vandroiy2013, Voodoo Team, Pike R. Alpha, lvs1974, Austere.J, CVad, headkaze, onemanosx, erroruser, Jenny David, Sampath007, Facebook Hackintosh comunidade, Facebook Olarila comunidade e muitos, muitos, muitos outros! Estamos todos aqui para nos divertir e aprender uns com os outros! .como abre esse config.plist?
Deivison Souza Posted January 10, 2023 Posted January 10, 2023 tenho o ALC256 ja fiz isso tudo e não resolveu config: enão vaio F14 i5 10210u comet lake UHD 620
Administrators MaLd0n Posted January 10, 2023 Author Administrators Posted January 10, 2023 DSDT IRQs Patch -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Deivison Souza Posted January 11, 2023 Posted January 11, 2023 On 1/10/2023 at 2:43 PM, MaLd0n said: DSDT IRQs Patch Daniel sou novo nessa área de hackintosh e estou criando ele para poder estudar programação. vi que você esta me dando a solução mas não sei como fazer esse DSDT IRQs Patch. meu notebook Vaio FE14 Intel i5 10210u cofe lake - commet lake No Windows informava intel UHD gráficas, no entanto o áudio eu resolvi... agora só falta usar o HDMI para usar COM meu monitor e quando a tela do notebook se apaga e entra no modo inativo a tela não LIGA mais tenho que forçar a reinicialização da maquina. SEM SOLUÇÃO: *HDMI *MODO INATIVO DE TELA
