35 minutes ago, renatonls said:
Thanks for your help
I copied the file to VoodooHDA.kext the Kexts folder
According to the model of my xxx board I tested the parameters in the ACLID 5,7,11,12,13,15,16,17,18 and 66
Even with all these tests the problem persists,
I'm sending the RunME result in case someone needs to analyze some other details
https://we.tl/t-A4zkTA3Svx
Why VoodooHDA kext ? You use AppleAlc.kext, in clover/ kext /other
Add to boot argument alcid=5 save, reboot test, alcid=7 save, reboot, test...........
The file was nominated by another member here at the Forum, but the AppleAlc.kext file is mentioned.
I changed the field to the IDs that I mentioned earlier and it didn't work.
Is there any other ID or anything else that I can try to do to activate the SOM?
3 hours ago, Hamed N53 said:
Hi.. I did all of those tricks but no success
On 5/20/2021 at 4:01 AM, MaLd0n said:
Edited by Hamed N53
Audio do not work.
AppleALC  did not work
My laptop is Toshiba Satellite S55-A,
Motherboard is Intel VG10F,
processor is I7-3630M,
sound card is Intel Panther Point PCH-High Definition Audio Controller [C1].
plz help me
Archive.zip
if applealc don't work for u u can use voodoohda
Hi everyone! Im new here, but I´m with hackintosh since Mavericks. I have good skills with chimera and clover. This is my first time with OpenCore. My Asus M5A99FX Pro R2.0 (with AMD FX3850) past away 2 weeks ago, and I bought an Asus B450M-A II, with AMD Ryzen 2200g (And my ATI HD7770 from the old one). I´ve installed Big Sur 11.4 with no issues. Everything is working even better than before (Clover), but I have Audio issues that I can´t solve by my own.
I have ALC887, and I´ve tested every layout, but audio keeps cracking and poping in all applications except web browsers (chrome, firefox, safari). It shows every connectors, and all of them works, but always cracking.
Now if I move the cursor, sound is perfect, and when I stop moving it cracking and poping again.
I´ve searched for two days, and no one tells anything about that.
Any thoughts?
Thanks in advance...
I have Dell Optiflex 5060 success with open core bigsur but no sound card. I try with your post but not success for sound
CPU: Intel I7 8700
Ram: 16gb
GA: Intel UHD 630
Quote
Quote
Sorry i don't know how to post images in this post
Edited by Khue Song
Add link RunMe
why u change things in Olarila folder?
just change smbios and video patch
17 minutes ago, shoya0x00 said:
can anyone help me
reset nvram with f11 key or boot with opencore and use reset nvram entry
I got Catalina dual boot with win11 after rebooting from win11 my audio is not working. System showing I have audio device but can't hear anything. Need help.......
38 minutes ago, shoya0x00 said:
Need help
try other layout-id
