edgarjones Posted July 4, 2019 Posted July 4, 2019 Hey, which OS you are using? I have a step by step guide to fix the issue. You can check this link, if it helps: https://techhowdy.com/fix-bluetooth-and-wi-fi-on-hackintosh-macos-sierra/ If it is not helpful for you, then please let me know the Operating System you use. There are different ways to fix the issues for different operating systems.
