[Guide] How to remove kext in system folders with Single User(-s)
--Remove kext using Single User
1- In Clover boot screen press BarSpace
2- Use -s option(single user)
3- Wait for root#
4- Type
a- System/Library/Extensions
mount -uw /
rm -rf /system/library/extensions/KEXTNAME.kext
exit
b- Library/Extensions
mount -uw /
rm -rf /library/extensions/KEXTNAME.kext
exit
Other Options
--Remove kext using USB Stick, Terminal
a-System/Library/Extensions
cd /Volumes/VOLUMENAME/System/Library/Extensions
rm -rf KEXTNAME.kext
b-Library/Extensions
cd /Volumes/VOLUMENAME/Library/Extensions
--Move kext using USB Stick, Terminal
mv /Volumes/VOLUMENAME/System/Library/Extensions/KEXTNAME.kext /Volumes/VOLUMENAME/FOLDERNAME
mv /Volumes/VOLUMENAME/Library/Extensions/KEXTNAME.kext /Volumes/VOLUMENAME/FOLDERNAME
