probook 4540s hd3000 problem
hi Daniel can you check for me the files I atached down below, because I have problem to make hd3000 working on any version of macOS I checked vendor id in ioreg explorer and it looks weird for me because vendor is same like hd4200 hd4400 and hd4600 but cpu is just 2nd gen i3 with hd3000 and don't know how to make them to work
Send-me-MacBook-Pro-Mateusz.zip
[ref]ziomalex[/ref], use it, reboot and extract new SEND_ME
CLOVER.zip
what native resolution?
[ref]ziomalex[/ref], post one photo in error screen
[ref]ziomalex[/ref], now the problem is a video, disable patches in devices/properties
HD3000 is native, in mojave don't work more, native no
[ref]ziomalex[/ref], create one usb installer with tools
