Hackintosh Hackintool - Video Patch - Fast and Easy Solution
[ref]pdevonie[/ref], vc tem de criar o seu patch, isso varia
Tentei todas as platforms-id porém todas sem sucesso. :(
Algum outra solução para fazer? Por esse programa, eu altero o platform-id e gero um patch, porém parece que não muda nada.
[ref]pi2in3[/ref], have many versions
[ref]pi2in3[/ref], u mod kext instead used patch on the fly?
[ref]pi2in3[/ref], yes, but with patches kext stay untouched, best and vanilla way
ok ,but why the kexts are mentioned in first page :
Gen 4: Haswell (Intel HD Graphics 4200-5200)
- S/L/E/AppleIntelFramebufferAzul.kext
- Support started with OS X 10.9.x
- device-id: 0x0D26 0x0A26 0x0A2E 0x0D22 0x0412
- AAPL,ig-platform-id (desktop): 0x0D220003 (default)
- AAPL,ig-platform-id (laptop): 0x0A160000 (default), 0x0A260005 (recommended)
[ref]pi2in3[/ref], the kexts is native in the system
there is a guide on how to set the hdmi and dvi output since I have a black screen but if I log in from a wiever team the video card is loaded at maximum capacity
Hi MaLd0n,
pls help...i dont know what's im doing wrong, when i click Generates Patch,
nothing happen, see picture attachment:
[ref]Dyos[/ref], check Graphic Device
Dyos, check Graphic Device
already check/tick Graphic Device, nothing generates when click Generates Patch,
any other idea what wrong, csrutil, spctl master all disable :roll:
[ref]Dyos[/ref],
<IMGUR id="drdsTYx"><a href=https://i.imgur.com/drdsTYx.png' alt='IMGUR>'>
<IMGUR id="EMY917Z"><a href=https://i.imgur.com/EMY917Z.png' alt='IMGUR>'>
Added in 13 seconds:
[ref]icinemagr[/ref], :shock:
[ref]icinemagr[/ref], why are you using a kabylake with maverisk your fine to go up to high sierra an if you get a amd gpu you can go up to catalina an that can be a reason that you having issues with an out dated OS
:superman:superman
