Hackintosh Hackintool - Video Patch - Fast and Easy Solution
Hey guys. I am trying to get my UHD 630 working and nothing works. I tried to follow this and when I booted screen just went black and I had to replace config.plist with my back up to reboot.
I tried this fix recommended by erroruser:
https://Olarila.com/forum/viewtopic.php?f=50&t=8685&start=480#p81264
IntelGFX 0x59128086
ig-platform-id 0x59120003
Check InjectIntel
shikigva=60
This did not work and it caused a kernal panic. I think what caused it was adding IntelGFX 0x59128086 as I did not get it with ig-platform-id 0x59120003 and shikigva=60
Any other things that I could be missing?
[ref]robnav[/ref], post ur files
--Run_Me
RunMe.app
[ref]robnav[/ref], try, replace full efi
EFI.zip
[ref]robnav[/ref], add it in device/properties
<key>PciRoot(0)/Pci(0x02,0)</key>
		<dict>
			<key>AAPL,GfxYTile</key>
			<data>
			AQAAAA==
			</data>
			<key>framebuffer-fbmem</key>
			<data>
			AACQAA==
			</data>
			<data>
			AQAAAA==
			</data>
			<data>
			AAAwAQ==
			</data>
		</dict>
[ref]robnav[/ref], here, remove intelgfx too
<IMGUR id="szT20i2"><a href=https://i.imgur.com/szT20i2.png' alt='IMGUR>'>
[ref]robnav[/ref], the format above is for txt app not clover configurator, just open with txt app and add
[ref]MaLd0n[/ref], First thank you for all the help you have offered. I would not have a hackintosh if it wasn't for this website and you. The above code didnt work. I am going to install high sierra because I have been reading the UHD 630 works out the box. Going to install it and report back. Hopefully, it goes smooth.
[ref]robnav[/ref], desktop don't need it, just injectIntel solve 90%
Hi friend!!
I tried to do it with my i7-4770K (Intel HD4600) but it doesn't create the necessary patch.
It's like it lacks more information, it doesn't work out like in your tutorial.
I guess why I didn't compile Lilu and weather ... ketxs
How can I do it?
Thank you!!
[ref]cachiputi[/ref], in ur case just InjectIntel solve, try it
[ref]cachiputi[/ref], skylake+ only
