Hackintosh Hackintool - Video Patch - Fast and Easy Solution
Thanks a lot, MalD0n and erroruser!
I will try tonight with these tips, so... considering that I only have the iGPU video (UHD 630), without a dedicated graphic card, I can try with the current smbios(18,1) or with macmini 8,1 or what erroruser recommends: imac pro 1,1 or imac 18,3
thanks!
Hi friends! So, I believe everything is ok after apply the patch/changes!
What I did:
- follow this guide
- Set Platform ID to 0x3E9B0007
- on the first try, change smbios to MacMini 8.1 and in connectors I changed the active connector (in red) by type hdmi, which is the correct one of the mother. Result: the hack boots but the screen looks all in shades of pink.
- So I changed three things: the smbios to imac 18,3 and changed this parameters in hackintool patch:
ID: 3E9B0007, STOLEN: 57 MB, FBMEM: 0 bytes, VRAM: 1536 MB, Flags: 0x00801302
TOTAL STOLEN: 58 MB, TOTAL CURSOR: 1 MB (1572864 bytes), MAX STOLEN: 172 MB, MAX OVERALL: 173 MB (181940224 bytes)
GPU Name: Intel UHD Graphics 630
Model Name(s):
Camelia: Disabled
Mobile: 0, PipeCount: 3, PortCount: 3, FBMemoryCount: 3
[1] busId: 0x05, pipe: 9, type: 0x00000400, flags: 0x000003C7 - DP
[2] busId: 0x04, pipe: 10, type: 0x00000400, flags: 0x000003C7 - DP
[3] busId: 0x06, pipe: 8, type: 0x00000400, flags: 0x000003C7 - DP
01050900 00040000 C7030000
02040A00 00040000 C7030000
03060800 00040000 C7030000
- As you can see, I went back to all the connectors as DP
- But in the hackintool patch, I turned on the option DP → HDMI (patch /advanced)
- Result: no more pink screen but video glitches issues
- So, I changed the smbios definition again to MacMini 8,1
- Result: everything seems to be ok now!!
- Now, all connectors appears as HDMI :whistle
But, as I only have a monitor, with an HDMI port ... and my mobo has only two outputs: hdmi and dvi ... well, II do not worry too much (or should it be something to worry about it being that way?)
I send you some screenshots to confirm that everything seems fine (for now, ja!)
The only thing that seems strange to me is that (supposedly) the values ​​of "stolen, fbmem" etc ss you can see in the previous parameters, but they do not seem to reflect or are different (as can be seen in hackintool screenshot)
for now, I tried the screen off and the sleep mode, and apparently it goes back well without black screen
Well, if everything seems perfect, I continue with this configuration ... but in any case I am attentive to advice and suggestions!
Many thanks for all that help, friends!
[ref]kultrun[/ref], to avoid glitches, use iMac18,1 smbios
good job
Thanks, MaLd0n!
I use actually the MacMini 8,1 definition and there are not glitches... but if you recommed iMac 18,1, maybe I'll try
the only thing is what I said... I change the parameters in hackintool to:
in VRAM section... but now, when I reboot (everything is ok) in hackintool shows: STOLEN 19 Mb / FBMem 9 Mb / VRAM 2048 Mb / Max Stolen 67 Mb / Total Stolen 20 Mb / Total Cursor 1 Mb / Max Overall 68 Mb
It seems like that wehn I open hackintool and select "framebuffer -- MacOs 10.14"
EDIT: In my Mobo I can set DVMT in 128 MB... So do I need to use the "DVMT pre-alloc 32 MB" option in hackintool? this option has something to do with the vram variables?
I don't have 4K monitor or screen... do I need to use the option "VRAM 2048 MB" ??
many thanks!
kultrun, to avoid glitches, use iMac18,1 smbios
[ref]kultrun[/ref], dvmt, use it in mobiles with bios/uefi without some options, in desktop just up in bios/uefi
VRAM 2048 MB, i think is only cosmetic, i don't see any diff
thanks MaLdon! I will do those changes for a final config.plist...
I'll tell you if everything is ok! :guitar:guitar
ultrun, dvmt, use it in mobiles with bios/uefi without some options, in desktop just up in bios/uefi
Hi, all is ok and fine in my hack!!
I attach the config.plist if anybody needs it... My mobo GA Z370 HD3 (two connectors: HDMI and DVI) and CoffeLake i5 8400 - Intel UHD 630
Just the last question: can I update Lilu kext and there are no issues with that? I suppose is better have the lastet lilu.ket... bu just in case, I ask :)
thanks a lot for all the help and dedication!
saludos desde Argentina
config.plist.zip
[ref]kultrun[/ref], yes you can update all kexts if they need to be
:superman:superman
Many thanks erroruser!
I don't know if it's necessary update some kets like Lilu, when everything seems to work great, but... many times users recommend that
something to advise: I do not know if it is related to having generated the patch for the video or with the current (newer) version of hackintool, but I had to generate the USB patch again because all the ports appeared as "internal"
saludos!
kultrun, yes you can update all kexts if they need to be
I just update to 10.14.3, but before that I have changed the config on my PC I put another SSD 1Tb and installed win10 on it and I put my graphic card on that pc (msi rtx 2080).
Since I plug the card I have some issue with graphic on the Hackintosh part of the pc, the igpu uhd 630 is no more recognized like it was before I installed the DSDT from Mald0n
here's a screenshot https://drive.google.com/file/d/1gqhsSXIrExWgTXL10a6qB1XoDukGn7Ch/view?usp=sharing
thanks for your help
also after the update I need to use a USB to boot into the hack now I have re-do the disablehibernate and master-command, and I just update clover too, I hope I will be able to boot normally now
[ref]adivajra[/ref], POST ONE FULL DUMP
--Run_Me
RunMe.app
we need disable nvidia in macos
[ref]gilgamet[/ref], :lol::mrgreen:
[ref]adivajra[/ref], DSDT.aml.zip
so it means I need to re install mojave since I can't boot,
I would have no problem with a complete re-install BUT when I installed windows I used bootcamp to create the usb windows bootable and I have noticed that the windows bootloader has been installed on the Nvme drive where is mojave and not on the SSD where I was thinking it will be (since I choose it during windows installation)
So I guess that if I have to do a complete re-installation I will loose access to windows 10... any idea?
I know this is me who totally forgot to put the correct clover folder for my chipset after I updated Mojave and then clover, but I must say that I could boot into the hack without problem after just re-doing the hibernate and master disable command (well except the UHD 630 not being recognized :roll: )
[ref]adivajra[/ref], u need check procedure about dual boot
ok i will but for now is there a way to force the boot to my hack, I think if it is possible to let clover boot without reading the acpi/patched ?
So I could then boot and change to the proper clover folder within mojave... :help
How to merge the Config.plist created by Hackintool with the one created with Clover Configurator?
Mount EFI or place working config.plist on desktop and export patch.
Donate
Gitter Chat
MSI B360 Gaming Arctic
Finally, I decided to re-install my hack, so I downloaded 10.14.4 from Olarila and made an USB bootable.
But I'm unable to install Mojave !
First I forgot to change the display port cable from my Graphik card to the onboard port = can't boot (freeze at less than 1 minute)
I add in arguments : uia_exclude=HS...., I changed to the mobo port still can not boot, same freeze.
So I took away the graphic card from the pcie but there is still the same problem!!!
I do not understand, because now it is the same conf. that was working before ?!?
Did I forgot something?
[ref]adivajra[/ref], check if problem is nvram, use emuvariable driver
