Hackintosh Hackintool - Video Patch - Fast and Easy Solution
hello @MaLd0n recently i added one more 8gb ram and now i have 16 gb , i was wondering is there anyway to share my ram with VRAM to get better overall performance , because on windows it shows 7.9 gb vram but on mac it's 2024 (dynamic,max) , You already patched my DSDT (i attached my dsdt and config.plist)
Lenovo Ideapad 300 15ISK
CPU: Intel i5 6200u with Intel HD 520
thank you :)
DSDT.aml config.plist.zip
36 minutes ago, guilty_baby said:
hello @MaLd0n
inject propertie framebuffer-unifiedmem with DATA 000000C0
is cosmetic
1 minute ago, guilty_baby said:
i did that but i got 3024 , can i have 7 or 8gb ?
cosmetic, just ignore
Hi, Im trying to enable my Intel UHD630, but only works with -igfxvesa. I do all in the guide (install, Post install, and Video Patch, also try the config in te install guide). Also with recommended settings cannot open, so i need to disable all de PCI devices from boot clover options. Help, please?
And also can´t open UEFI Bios Setting...?
Asus b365m-a
I5-9400
16 GB
Wd-SN750
Mojave 10.14.6
EFi+configs.zip
2 hours ago, Diego Alegre said:
Asus b365m-a
check hackintool. have many patches in menu
use igfxonln=1
Hi ... I need help I can't enable the HDMI port of my Dell laptop has a KabyLake 7700HQ Intel HD630 graphics processor. I have Big Sur OpenCore installed. Please help me
use this patch with smbios MacBookPro14,1
Quote
<dict>
<data>AADAhw==</data>
<key>device-id</key>
<data>FlkAAA==</data>
<key>framebuffer-con1-alldata</key>
<data>AQUJAAAIAACHAQAA</data>
<data>AQAAAA==</data>
<key>framebuffer-con2-alldata</key>
<string>&lt;02040a00 00080000 87010000&gt;</string>
<key>framebuffer-fbmem</key>
<data>AACQAA==</data>
<data>AAAwAQ==</data>
</dict>
Hello! ?
I'm have issues with this hardware:
Motheboard:
b150m/c BR
Processor: i3 7100
16GB RAM
256GB SSD
I would like to use my hack with two screens. In OpenCore Guide, it is recommended to use iMac 18,1 SMBIOS for KabyLake but my screen 1 sleep in exactly moment screen 2. For the solution in this case, I need to change my SMBIOS to iMac 19,1 and my screen 1 starts normaly without issues in screen 1.
For use two screens, i tried to this tutorial but i dont have success. (And i tried iGPU patch for the OpenCore Guide too).
My motheboard have an 4 connections:
1 HDMI
1 DP
1 DVI (Burned in try to work with 2 monitors)
1 VGA
I suspect that this has an issue with SMBIOS but i dont have houg knowlege to continue after this tutorial not solved.
You can help me?
Edited by Duduzera
1 hour ago, Macpig said:
How can I Patch video for 1700K  Rocket Lake and RX 560?
rx560 have native support
Como é o procedimento para adicionar esse patch? essa parte que nao esta muito clara para mim. Voce gerra o config.plist e salva na desktop, mas em qual momento por exemplo foi adicionado a partição efi? essa parte que de fato nao entendi.
dê uma olhada nas pasta EFI Olarila, Device Properties
https://www.olarila.com/topic/5676-hackintosh-efi-folders-for-all-chipsets-clover-and-opencore/
1 hour ago, MaLd0n said:
quando eu gero esse patch e adiciono em <DeviceProperties><add></add></DeviceProperties>, que eu reinicio o sistema trava e não sai do canto, ai entro pelo ubuntu edito o arquivo na partição efi e volta a funcionar. peguei um patch que voce me passou ja tem um tempo. ele não trava o sistema, mas a placa onboard continua mostrando 7mb.
            <dict>
                <key>#framebuffer-patch-enable</key>
                <data>AAASGQ==</data>
                <data>EhkAAA==</data>
                <key>framebuffer-unifiedmem</key>
                <data>AADw/w==</data>
            </dict>
para conseguir instalar eu precisei colocar no boot-args -igfxvesa, precisa remover para esse patch funcionar?
qual o seu processador?
Hi, I'm trying to enable the hdmi ports but I can't, someone can help me, my hardware
motherboard msi z170a gaming m7 cpu skylake i5 6600k intel 530hd
Monterey 12.4
thank you
Edited by NonMollo
Quote
            <dict>
            </dict>
i tied generating in hackintool but after i export into config and open it via clover configurator and opencore configurator, the device property is empty. i dont know why its empty, i tried to export it via text, and its not empty
please help me. thanks
