Hackintosh Hackintool - Video Patch - Fast and Easy Solution
--Donations--
https://olarila.com/topic/40727-support-the-olarila-forum/
-Download Hackintool by headkaze
https://github.com/benbaker76/Hackintool/releases
Hackintool is a Swiss Army Knife, here we just check a fast and good video patch, in some cases need a extra procedure, if you use a patch by Hackintool, remove InjectIntel, ig-platform-id, SSDT about video, DSDT patch about video.
I'm using my KabyLake i3 mobile for create this tutorial
Some recommended configs:
Gen 2: Sandy Bridge (Intel HD Graphics 2000/3000)
- S/L/E/AppleIntelSNBGraphicsFB.kext
- Support started with OS X 10.7.x and ended with macOS 10.13.6
- Metal support is not available
- device-id: 0x0102 0x0106 0x010A 0x0112 0x0116 0x0122 0x0126
- AAPL,snb-platform-id (desktop): 0x00030010 (default)
- AAPL,snb-platform-id (laptop): 0x00010000 (default)
Gen 3: Ivy Bridge (Intel HD Graphics 2500/4000)
- S/L/E/AppleIntelFramebufferCapri.kext
- Support started with OS X 10.8.x
- device-id: 0x0152 0x0156 0x0162 0x0166
- AAPL,ig-platform-id (desktop): 0x0166000A (default), 0x01620005
- AAPL,ig-platform-id (laptop): 0x01660003 (default), 0x01660009, 0x01660004
Gen 4: Haswell (Intel HD Graphics 4200-5200)
- S/L/E/AppleIntelFramebufferAzul.kext
- Support started with OS X 10.9.x
- device-id: 0x0D26 0x0A26 0x0A2E 0x0D22 0x0412
- AAPL,ig-platform-id (desktop): 0x0D220003 (default)
- AAPL,ig-platform-id (laptop): 0x0A160000 (default), 0x0A260005 (recommended)
Gen 5: Broadwell (Intel HD Graphics 5300-6300)
- S/L/E/AppleIntelBDWGraphicsFramebuffer.kext
- Support started with OS X 10.10.2
- device-id: 0x0BD1 0x0BD2 0x0BD3 0x1606 0x160E 0x1616 0x161E 0x1626 0x1622 0x1612 0x162B
- AAPL,ig-platform-id (desktop): 0x16220007 (default)
- AAPL,ig-platform-id (laptop): 0x16260006 (default)
Gen 6: Skylake (Intel HD Graphics 510-580)
- S/L/E/AppleIntelSKLGraphicsFramebuffer.kext
- Support started with OS X 10.11.4
- device-id: 0x1916 0x191E 0x1926 0x1927 0x1912 0x1932 0x1902 0x1917 0x193B 0x191B
- AAPL,ig-platform-id (desktop): 0x19120000 (default)
- AAPL,ig-platform-id (laptop): 0x19160000 (default)
Gen 7: Kaby Lake (Intel HD Graphics 610-650)
- S/L/E/AppleIntelKBLGraphicsFramebuffer.kext
- Support started with macOS 10.12.6
- device-id: 0x5912 0x5916 0x591B 0x591C 0x591E 0x5926 0x5927 0x5923 0x87C0
- AAPL,ig-platform-id (desktop): 0x59160000 (default)
- AAPL,ig-platform-id (laptop): 0x591B0000 (default)
Gen 8: Coffee Lake (Intel UHD Graphics 630)
- S/L/E/AppleIntelCFLGraphicsFramebuffer.kext
- Support started with macOS 10.13.6 (17G2112) / 10.14 beta 4 (18A336e)
- device-id: 0x3E9B 0x3EA5 0x3E92 0x3E91
- AAPL,ig-platform-id (desktop): 0x3EA50000 (default), 0x3E9B0007 (recommended)
- AAPL,ig-platform-id (laptop): 0x3EA50009 (default)
Spoofing Intel CPU Gen
If you need to spoof a different Intel CPU generation you can use the lilucpu=N boot flag. The N refers to the following Intel generations:
4    SandyBridge
5    IvyBridge
6    Haswell
7    Broadwell
8    Skylake
9    KabyLake
10   CoffeeLake
Here are some reasons why you might need extra Framebuffer Patching:
- Setting DVMT for those who can't set it above 32 MB in BIOS (framebuffer-stolenmem / framebuffer-fbmem)
- Setting higher VRAM for 4K users who experience graphical glitches (framebuffer-unifiedmem)
- Disabling eGPU (disable-external-gpu)
- Enable pixel clock patch for 4K support (enable-hdmi20)
- Disabling connectors to enable sleep (framebuffer-pipecount / framebuffer-portcount / framebuffer-conX-type=-1)
- Removing CNConnectorAlwaysConnected flag for eDP laptop screens on < 10.13.6 (framebuffer-con0-flags=0x00000090)
- Changing connector types to match your systems ports (framebuffer-conX-type)
Framebuffer Patching Types
We have three different types of patches:
1. Arbitrary (Recommended)
framebuffer-patch-enable (required to enable below)
framebuffer-framebufferid (optional; defaults to current platform-id)
(all below are optional)
framebuffer-mobile
framebuffer-memorycount
framebuffer-fbmem
framebuffer-cursormem (Haswell only)
framebuffer-camellia
framebuffer-flags
framebuffer-conX-enable (required to enable below)
framebuffer-conX-index
framebuffer-conX-busid
framebuffer-conX-pipe
framebuffer-conX-flags
2. All Data
framebuffer-conX-alldata
3. Find / Replace
framebuffer-patchX-enable (required to enable below)
framebuffer-patchX-framebufferid (optional; defaults to current platform-id)
framebuffer-patchX-find
framebuffer-patchX-replace
framebuffer-patchX-count (optional; defaults to 1)
Let's Start
-Open App, Go to Menu, Framebuffer and select your system version
-Go to Intel/Info tab, select your Intel Generation(in my case is KabyLake), select PlatformID(for me work with 59160000 or 591B0000)
-Now go to Patch tab and select Devices / Properties, All, Connectors, VRAM, Auto Detect Changes and Use AllData Method
-Go to Advanced tab and select:
-DVMT pre-alloc 32 MB
-Disable eGPU
-VRAM 2048 MB
-Enable HDMI20 (4K) - same boot-arg -cdfon
-GfxYTile Fix - Skylake+ IGPUs
-Device ID - in some case we need it to fake a device id, same IntelGFX in Clover config.plist
-Go to Generate Patch
-Export config.plist, go to Menu, File, Export, Clover config.plist
-Save
-Result
Credits
- headkaze, vit9696, lvs1974, RehabMan, pikeralpha
  • Like 5
  • Thanks 1
:guitar
:superman:superman
[ref]onemanosx[/ref], [ref]erroruser[/ref], :guitar:guitar if need sugestions, ig-platform-ids etc, tell me, i'll add some today
You are the Best Man!!! Thanks!!! Im will test and fine tune for my GPU!!! :guitar:superman:D
Gigabyte Aorus Z790 Elite AX / Raptor Lake 13th Intel® Core™  13900K / AMD AORUS RX 6900 XT  2 rev. / Lenovo E470 i5-7200-U Kaby Lake iGPU intel HD620 64 GB Ram / ASUS Prime B365M-K Desktop intel i3-Coffe Lake / ASUS Sapphire Nitro+ AMD RX 580 4GB / Gigabyte B360 i5-Coffe Lake / RX 64 Vega OC Gigabyte / Gigabyte B660 Raptor Lake 13th Intel® Core™ i7-13700K  / Nvidia GeForce GTX 3060 Gainward 12GB /  Gigabyte Z170 XP SLi  Intel® Core™ i7  iGPU /  Mac mini M4 Pro 12/16  24 GB Ram  512 GB Nvme /   MacBook Air 2020 10th Ice Lake Intel® Quad-Core™ i7-1060NG7 T2  Iris Plus Graphics  /  Clover Hacky Color 5161  / Opencore 1.0.4 /  God Bless you!
[ref]max.1974[/ref], :guitar:cap
[ref]Allan[/ref], credits to headkaze :mrgreen:
[ref]aerz[/ref], welcome, bro!
[ref]steezy[/ref], welcome and enjoy! :mrgreen:
very nice! Thank you Mald0n!
well in my case as for now I'm a bit scared to mess with the stuff Mald0n as done for me,
but I just have only 1536 Mb VRAM on my UHD 630
I'm using displayport, but the fact is HDMI for now does not work at any resolution.
I'm waiting a bit but I will probably buy an rx 590 to solve any video related problems.
By the way can I do the update 10.14.3 and if it is possible how to do it?
thanks
[ref]adivajra[/ref], "always" make a backups an have instaler usb ready for recovery before trying things out ;)
before updating update kexts what i use is kext updater for the essential kexts https://bitbucket.org/profdrluigi/kextupdater/downloads/
backup i recommend carbon copy cloner then download update from app store an run from desktop
:superman:superman
Hi friends, Thank you very much for the guide!
I will try this method with my mobo GA Z370 HD3 and Coffe Lake i5 8400 processor (UHD 630 Graphics)
I already made the file config.plist using this guide and now I just have to try placing it in the EFI partition and restart the Hack. So, before I have to remove InjectIntel in clover settings and remove anything else there or from DSDT file? (I attached the current dsdt performed by Maldon)
And an important query: since I only have one monitor, currently connected to the motherboard's hdmi port, in case something does not work well with the changes made with hackintool, is it possible to restore the backup config.plist (prior to the changes) from the clover boot?
Since I am still quite new, I do not know the methods to restore clover's config.plist in case some changes made break the boot and the Mac OSdoes not start or not work correctly
many thanks, friends!
[ref]kultrun[/ref], ur GPU work good? desktop u can use a other way, intelgfx and ig-platform-id
just create a copy of your original config eg:"config2"for testing an you can select in the in the options section of the bot screen by pressing "O" then if all is good an stable you can rename to use
:superman:superman
oh, many thanks friends!
I did not know this method to boot choosing a particular config.plist, very good option! I'll try and i'll tell youy if everything is ok
Maldon: "kultrun, ur GPU work good? desktop u can use a other way, intelgfx and ig-platform-id"
Yes, for now mi iGPU works ok, excepto for some sleeping issues... but I have full acceleration, full HD etc
But it currently works with the injectintel option, not the hackintool method... maybe that's why I'm wondering if it's worth changing the method, if there are any improvements (there are some sleeping issues with black screen and the connectors dosn't match with the mobo, eg. there is a LVDM port...)
many thanks!
I'm having problems, when I put in the patch, it does not appear any more, when I put any other video card of the intel, it insists on staying on this screen, what should I do?
ttps://uploaddeimagens.com.br/imagens/foto-png-743f73c8-61fe-4251-9bd9-d1129ed81d25
[ref]pdevonie[/ref], report it in developer topic
Hi, just a more question ... when you said "remove SSDT about video, DSDT patch about video"... it means also that I must delete any clover entrys about "GFX0 to IGPU"?
also "HDAS to HDEF"? and anything else? I attach my config.plist before apply the hackintool patch for video platformid etc
thanks!
config.rar
[ref]kultrun[/ref], no, don't remove renames, only InjectIntel or other patch if u use
Ah, ok... thanks MaLd0n!
I believe there are not any other patch in my hack... just the dsdt.aml provide by you (after sending you the resulting file of Runme). There is information about Intel Graphics UHD 630 in that dsdt.aml, in PCI section... but I think that's not a problem, right?
considering my mobo GA Z370 HD3 and the CoffeeLake 8400 i5 processor (with Graphics UHD 630), it is recommendable to use the definition of SMBIOS as MacMini 8.1? (Actually, I use the Imac 18,1 SMBIOS)
many thanks!
kultrun, no, don't remove renames, only InjectIntel or other patch if u use
[ref]kultrun[/ref], both work good
Added in 38 seconds:
no problem
[ref]kultrun[/ref], for cofeelake either imac pro 1,1 or imac 18,3
:superman:superman
