Jedispara Posted November 22, 2011 Posted November 22, 2011 Hey guys, i've been struggling for over a week now to get my system up and running, and while I can get Lion installed with no problem, I keep hitting a brick wall for ethernet and audio. I've posted a few times over on tonycrap with no success, and its getting critical that my machine get up and running, as its where i do the primary amount of work for my own small business. The Hardware MoBo: Intel DX58S0 - Bios revision 5506 (most current) - Audio according to the intel site is Realtek ALC889 - Intel® 82567LM Gigabit Ethernet Controller CPU: i7 970 GFX: Sapphire Radeon 5770 Ram: 12GB Corsair Vengence HDD: 6 WD 1TB Green drives in Raid 1/0 (stripping over 3 mirrors) I'm using the tonycrapX86 unishit system to install lion on the hard drives with great success. The actual install takes under 10 minutes and i'm back at the Chimera boot screen from the USB stick. As a side note, at the end of it all i'm using the guide here to get the boot-loader installed on the boot segments of the raid array. I have also been using the guide here for what options to select in multishit, but if the number of kext's/options can be slimmed down, i'm sure its better. Where I'm running into great difficulty is with Audio and Ethernet. I know, they are supposed to be the hardest, but i've tried everything I can think of. Initially I simply used Multi-beast to limited success. Since then i've started working on a fully customized DSDT file to try to get the machine running as vanilla as possible. I've tried every combination I have been able to find online, searching exhaustively and I still can't get the audio or ethernet to work fully. ALSO (EDIT) - I've discovered your DSDT patches on this site and have been using that as a base for preparing my DSDT. 1) Ethernet - seems to sometimes work and sometimes not, and there is no explanation, is there a known fix to make it work fully. 2) 5.1 Audio from the ALC889 - I've gotten output but no input, or input and no output, trying numerous different DSDT and KEXT fixes for this. I need 5.1 audio for my business, or at bare minimum functioning output AND input at the same time. I've been looking into bin-patching, but I can't make any headway with this. Other than these 2 issues, the machine runs nearly flawlessly with relatively few fixes. Thank you in advanced for your time and let me know if you need any files from me.
el coniglio Posted November 22, 2011 Posted November 22, 2011 Here are the kexts I use http://www.mediafire.com/?rnntfh3ksmcyjh2 http://www.mediafire.com/?8ka4lv9amekaa6s For ethernet you can also try this one http://sourceforge.net/projects/osx86drivers/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Jedispara Posted November 22, 2011 Author Posted November 22, 2011 Are you using any customization to the DSDT file?
el coniglio Posted November 22, 2011 Posted November 22, 2011 Yes, the DX58SO "pack" available here http://Olarila.com/forum/packs.php -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Jedispara Posted November 22, 2011 Author Posted November 22, 2011 The audio is working quite nicely now. But the ethernet still refuses to work. I've tried both drivers, is there anything i need to clear out of the system to get it to work?
Cassio Posted November 22, 2011 Posted November 22, 2011 Try sudo mv /System/Library/Extensions/IONetworkingFamily.kext/Contents/PlugIns/AppleIntel8254XEthernet.kext ~/Desktop sudo touch /System/Library/Extensions -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Jedispara Posted November 22, 2011 Author Posted November 22, 2011 No luck with that shell command. I've got the AppleIntel8256X.Kext installed, its in the S/L/E folder if that makes any difference
Cassio Posted November 22, 2011 Posted November 22, 2011 Was AppleIntel8254XEthernet moved to the desktop? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Jedispara Posted November 22, 2011 Author Posted November 22, 2011 Yep, its currently sitting on the desktop. I've also done a reboot just to be safe.
Cassio Posted November 22, 2011 Posted November 22, 2011 Do you use kernelcache or mkext? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Jedispara Posted November 22, 2011 Author Posted November 22, 2011 in the org.chameleon.boot UseKernelCache = yes. And as far as I know I didn't set anything regarding mkext.
Jedispara Posted November 23, 2011 Author Posted November 23, 2011 I'm going to do a full re-install of Lion on the hackintosh using as few hacks as possible listed below... DX58S0 DSDT edit from this site along with the HDEF edit to remove the need for a HDAEnabler AppleIntel8256X.kext (from this thread) VoodHDA.kext (from this thread) multishit with no audio kext selection or ethernet selection, using UserDSDT, and also using Chimera 1.6.0 for a bootloader I'll let you know how it goes.
Jedispara Posted November 23, 2011 Author Posted November 23, 2011 OK, so audio working fine, ethernet still no go. Patches I ended up using - DX58S0 DSDT patch using DSDT Editor after extracting the DSDT using DSDTFixer to remove a min/max/length error. - Did the following steps using multishit 4.1.0 - - System Utilities - - Drivers & Bootloaders - No audio or ethernet selected - IOAHCIBlock... & 3rd Party Esata - Evoreboot, FakeSMC, NullCPUPower, Chimera (bootloader) - After installing with multishit I applied the VoodooHDA and AppleIntel8256X Kext files from this thread using Kext Helper b7 - Removed AppleHDA from the S/L/E folder and also ran the shell commands from earlier in this thread for the ethernet - Finished up by going through the following how to install on raid 0 guide to make the machine HDD bootable. End result is me still scratching my head. I've run the System Info program from the Kext area here and for the ethernet controller its showing the above mentioned kext file as the one for the controller, but for what ever reason the control panel refuses to get a proper IP from DHCP, or even when i put in a static IP, nothing will contact the outside (safari, pinging something etc). Also to note is that when i go into the system panel > network, it shows ethernet as connected, but if i go to network diagnostic from safari it shows as ethernet not connected. Hope this helps Cassio, and I really appreciate your help with this so far. EDIT - On the other hand, unplugging and replugging in my network cable fixed it? Rather mystified on this one.
Cassio Posted November 23, 2011 Posted November 23, 2011 So, is it working now, or do you have to re-plug it every boot? You can enable "generate P & C states" in Chameleon and remove NullCPUPM. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
freethinker Posted November 23, 2011 Posted November 23, 2011 I have DX58SO, with i7-920 CPU, 6GB Triple Channel Ram, GT9500 1Analog/1DVI Video. I Used unishit to install the OS and the Lion version of multishit (I copied all of the OS Updates, multishit and installation files onto the unishit USB Drive First) to install the bootloader and most of the drivers. When I used multishit, I had to use EASYBEAST because i am having a problem with the DSDT, Then I Had to use the E1000e LAN Driver and the ApplieAzilla Audio Kext using kext helper and had to set the System Power management to never because the system does not come out of sleep properly. I recently found a DSDT inside of the DX58SO installer package and will the auto patcher and see if i get the DSDT to function and have my energy saving setting to work properly. But I am going to wait untill i get a Dual DVI Video card working properly. I Hope this Helped.
Jedispara Posted November 24, 2011 Author Posted November 24, 2011 Ethernet seems to work fine on reboot, its just its initial initialization with the new driver apparently requires it to be re-plugged in.
Jedispara Posted November 24, 2011 Author Posted November 24, 2011 One last question and I should be completely set on this machine. I have a DVD drive that i would like to plug into the eSATA port on the back. Now the chipset is Marvell 88SE6121 Sata II controller (Dev ID - 6121). I did a search on the kext portion of this site and found several and was just wondering if you had any recommendations as to which one to use. *Update* in the bios the only 2 options are IDE and RAID, now the DVD drive is recognized in the bios properly, and the bios is set as IDE currently, let me know if this needs to change. Thanks in advanced!
Cassio Posted November 24, 2011 Posted November 24, 2011 The Marvell controller is supported by VIA ATA kexts. http://nawcom.com/osx86/files/10.6/SATA/VIA/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Jedispara Posted November 24, 2011 Author Posted November 24, 2011 I guess this would be important information as well, I'm trying to use a LG HL-DT-ST GSA-H62N dvd drive plugged into the eSATA port (via a SATA to eSATA cable). I don't know if this changes anything. But the dvd drive is atleast recognized by the BIOS. Also i've been trying the VIA ATA kext, when i reboot i seem to be getting intermittent KP's. Trying a fresh install again using the method I used earlier in this thread.
Cassio Posted November 24, 2011 Posted November 24, 2011 Some versions of AppleVIAATA have problem with more than 2 GB of RAM, try another one. This one claims to solve the problem, but it's 32 bit only http://code.google.com/p/darwin-ata/downloads/list -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
