Hi! I'm trying to install MacOS Mojave on a PC that I got but I have a problem, when I try to run the installer once the installer finishes loading, the screen goes black, I tried with XFX RX 570 and GIGABYTE RX 570 8GB and the configs RadeonDeInit, "-v GraphicsEnabler=Yes IGPEnabler=No", UEFI, Legacy... and I can get it work only with a little trick, once the installer loads and the screen goes black I wait the computer to get to sleep and when I push the power button the Language selection appears. Also I updated the BIOS, selected PCIE Graphics Card in BIOS and ACHI. I need a little help, thanks
Motherboard: ASUS P8H61-M PRO
Processor: Intel Core i5 2300 (Sandy Bridge)
RAM: 8GB DDR3
Graphics Card: XFX RX 570 or GIGABYTE RX 570 8GB
This boot-args: -v GraphicsEnabler=Yes IGPEnabler=No
Are not for Clover.
Boot your Hack with the USB stick, and put WhatEverGreen.kext inside Clover/kexts folder.
Thanks & Regards
RadeonDeInit not needed xfx no good use this clover
https://Olarila.com/files/Clover.Folder/CLOVER.SERIES.CHIPSET.zip
:superman:superman
:superman:superman
Hi, why do I need to use this?
for generate a full dump
it so i can see the setting in the clover folder to help make sure things are set correctly an also it help maldon to complete a dsdt patching to help your system be stable an work well
:superman:superman
