Hi maldon,
Thanks for helping the community. I have tried my best to do the patching the DSDT and need your help with finalizing it and validating.
Can you please look at mine and see if everything looks good or will you be able to patch them ?
https://ufile.io/unhui
Things i have done
  • Fixed errors and warnings
    Did apply some patches created by nmano for the x99 platform
Things I need help with
  • Validating the DSDT (If I have messed up everything, can you create a new one ?)
    Need to know if I could edit the DSDT to be in the 15 port range by commenting unwanted HSXX and SXXX ports
