Hi I have another problem to solve but now with Probook 450 G3, I am running lates macOS Mojave with no problems but there is some issue with my bluetooth.
I have dell 1560 wireless bluetooth adapter and wifi works ok bluetooth recognised ok but not finding any devices and I can not make it discoverable, all kexts are placed in S/L/E cache rebuild etc. do you know what can cause that problem?952801434_Screenshot2019-02-20at16_46_46.thumb.png.6aa3856a1c16d43c0586a896946fdccf.pngSend me Probook-MacBook-Pro.zip
872546899_Screenshot2019-02-20at16_47_05.thumb.png.776215feab840e93f8e7faa5c519ff20.png
1889668908_Screenshot2019-02-20at16_48_16.thumb.png.53d7ce6e85d5be84a55389b27b75bf17.png
remove kexts are placed in S/L/E you put in an use these in the other folder as where they should go https://drive.google.com/drive/u/0/folders/1PK1U72cw8qTnsQ1pKwNJswhUvE7719hx
:superman:superman
3rd party kext do not need to go in the s/l/e
Added in 27 seconds:
easier to block if issues if in the other folder
:superman:superman
