hi I finally decided to reinstall my high Sierra on dell 5577 with i5-7300hq hd630 and alc256 audio but unfortunately I can not get my audio working, I have been trying using Hackintool to create patches for my audio but non of these layout Id's not work for me, I don't know what to do more with it
P.S i also try to use mirone's app for patching had but it told me the my audio codec is not supported or something that kind
Send me iMac-Marcin.zip
for layout id use 5,11,13,21,28,56 test each one an reboot after each change if also unsuccessful you may need to use voodoohda
https://sourceforge.net/projects/voodoohda/
:superman:superman
thats the problem I used all layouts and no luck but I seen posts on different sites (goes which ones) and some people get it working by some patches but I had no idea how they did that. I didn't want to use voodoohda because of bad sound quality and they not using my built in subwoofer
you have to open the kext by right click to show package contents open contents open infoplsit with textedit an edit here
PCM
90
Rec
90
iGain
90
iMix
90
to set the speaker you need to use midi in the apps/utilities folder
:superman:superman
PCM
90
Rec
90
iGain
90
iMix
90
the kext has already that values, do I need to put different values there or everywhere 90?
yes you need to raise them "100" to start need higher raise numbers
:superman:superman
just shame that voodoo had sound is very flat, I just get my cdmi working for my hd630 using iris 640 platform id and I bought that I can make my sound working properly with apple had/alc
[ref]ziomalex[/ref], try it with applealc
unfortunately it didn't help, I did fresh install to be sure that applehda is untouched but no luck I tried apple alc, I did use Mirone's patcher and nothing so I think I will have to stick with voodoohda and poor sound quality
