pikaciù Posted February 15, 2019 Posted February 15, 2019 (edited) With the RunMe app it goes into error or follows the video of MaLd0n (RunMe Mojave) but the same by mistake I attach photos. AsusPro E520 ( Micro Pc ). Cpu I3 7100T Video HD 630 Ram 2x4GB DDR4 2400mhz M2 kingstone 96GB < Mojave 10.14.3 HD disk 1TB N.1 Hdmi. N.1 DisplayPort. <- Monitor Lenovo 27 + Audio ). N.1 Ethernet RealtekRTL8111 N.4 usb 3.0 N.1 usa 2.0 1 jack Mic. 1 jack Cuffie. M2 key Dell Wifi e Bluetooth. I use the USB 3.0 Adapter Ethernet RJ45 Lan Gigabit or wifi . With Realtek RTL8111 ethernet or connection problems. while bluetooth or problems connecting to the mouse and keyboard. in the bios there is no setting for the DVMT Edited March 23, 2020 by pikaciù
Administrators MaLd0n Posted February 15, 2019 Administrators Posted February 15, 2019 [ref]pikaciù[/ref], DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
pikaciù Posted February 15, 2019 Author Posted February 15, 2019 [ref]pikaciù[/ref], DSDT.aml.zip thank you.. I still have the problem of bluetooth that does not detect mouse / keyboard / headphones do I have to add some Kext?
Administrators MaLd0n Posted February 15, 2019 Administrators Posted February 15, 2019 [ref]pikaciù[/ref], check Olarila clover folder for correct config usb is here https://Olarila.com/forum/viewtopic.php?p=65287#p65287 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
pikaciù Posted February 16, 2019 Author Posted February 16, 2019 (edited) Quote bluetooth bluetooth problem solved so. Removed all Kext from Efi \ Clover \ Kexts \ Other Put all the kexts in L \ E Reconstructed chache. the pc also 4 hours sleep I send it on the bluetooth keyboard and wakes up .. In the boot config: uia_exclude = HS06; HS07; HS08; HS10; SS05, SS06, SS07, SS08, SS09, SS10 System Parameters: Iniect Kext = No Thank you so much MaLd0n Edited March 23, 2020 by pikaciù
Administrators MaLd0n Posted February 16, 2019 Administrators Posted February 16, 2019 [ref]pikaciù[/ref], -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
