seje.1 Posted January 21, 2019 Author Posted January 21, 2019 [ref]erroruser[/ref], My bios system have these in the motherboard interface: Set OS Type to Other OS Set XHCI Handoff to Enabled UEFI only to enable and i have set them to that But does the same thing ):
erroruser Posted January 21, 2019 Posted January 21, 2019 look through an see that you have a dsdt file you can not use a dsdt file for installation as they are only for one system AMD Ryzen 7 3700X, MSI MPG X570 Gaming Plus, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, Sapphire rx 5700 XT, fractal celcius s36 HP Notebook - 15-ay028ca (Touch), 16 GB 2133 MHz DDR4, Intel HD Graphics 520 1536 MB Asus z97-c i5, i5 4460, 32 GB 1648 MHz DDR3, Radeon RX 560 4096 MB, Corsair H75 Liquid CPU Cooler
seje.1 Posted January 21, 2019 Author Posted January 21, 2019 (edited) [ref]erroruser[/ref], Okay, i have used a dsdt file from one there have the same specs. But if you say it's only for one system this not one i can use. Maybe it's that give all the problems i have. https://Olarila.com/forum/viewtopic.php?f=50&t=6255 First... If you need DSDT edits... -Reboot and extract original tables, press F4 in Clover boot screen, files generated in Clover -Run it and send me files The files generated in the folder clover->acpi->origin? This the method? Edited January 21, 2019 by Guest
erroruser Posted January 21, 2019 Posted January 21, 2019 for dsdt you do not need till after the install is completed then you extract an use the runme app just cause someone has same specs there are differences that will still not work so in saying that DO NOT USE SOMEONE ELSES AMD Ryzen 7 3700X, MSI MPG X570 Gaming Plus, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, Sapphire rx 5700 XT, fractal celcius s36 HP Notebook - 15-ay028ca (Touch), 16 GB 2133 MHz DDR4, Intel HD Graphics 520 1536 MB Asus z97-c i5, i5 4460, 32 GB 1648 MHz DDR3, Radeon RX 560 4096 MB, Corsair H75 Liquid CPU Cooler
seje.1 Posted January 21, 2019 Author Posted January 21, 2019 [ref]erroruser[/ref], I understand. I finally made it work!!! - The problem was a bad usb drive. Added in 2 minutes 25 seconds: [ref]erroruser[/ref], Thx for your help, at you be patient
erroruser Posted January 21, 2019 Posted January 21, 2019 happy hackintoshing AMD Ryzen 7 3700X, MSI MPG X570 Gaming Plus, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, Sapphire rx 5700 XT, fractal celcius s36 HP Notebook - 15-ay028ca (Touch), 16 GB 2133 MHz DDR4, Intel HD Graphics 520 1536 MB Asus z97-c i5, i5 4460, 32 GB 1648 MHz DDR3, Radeon RX 560 4096 MB, Corsair H75 Liquid CPU Cooler
