[ref]ivandmpk[/ref], ;):cap
Daniel is it Safe to update ?
Here is a nice modern edit of a folk song from my country for you :)
Turn the volume up !
[ref]ivandmpk[/ref], use carbon copy to make a back up first an make sure kexts are up to date before attempting any updates use this app to help you with kexts
https://bitbucket.org/profdrluigi/kextupdater/downloads/
:superman:superman
use carbon copy clone like i mentioned above in last comment i made an copy your efi also to a safe place
:superman:superman
I did the back up of my main SSD to another SSD with Carbon Copy Cloner . I will report how the update went.
Added in 27 minutes 55 seconds:
I think it all went well .
Added in 42 seconds:
This is how I run Pascal card in Mojave :D very happy with the outcome . This is exactly what I need.
I did this already and it's not working ... kinda anoying but ... I did it before on High Sierra and it works. I edit the copy of the file on my desktop and then replace it in the System folder... reboot and it's still Unknown
1873106132_Screenshot2019-01-20at2_50_01.thumb.png.5729d01b13e6558f3859e54b68ec1515.png
1) Open a Finder window, navigate to the System folder, and then to the Library folder inside. (Not the “Library” folder we visited in the Model name section).
2) Inside Library, go to PrivateFrameworks, and find AppleSystemInfo.framework
3) Inside this framework, navigate to /Versions/A/Resources/. Then find the folder for your system language. If yours is English, go to English.lproj.
4) Inside that folder, find the file AppleSystemInfo.strings. Copy the file, and paste one somewhere as a backup. Then paste another copy to your Desktop to edit. Do not try to edit the file in place, it will not work.
5) Right-click the copy on your Desktop and open it with your editor of choice use textmate https://macromates.com/
:superman:superman
I swear I'm doing it right :D ... after editting the file on my desktop with TextWrangler.app and replacing it in the folder (aaand reboot) it still Unknown
Added in 4 minutes 13 seconds:
there it is
1465410335_Screenshot2019-01-20at3_39_00.thumb.png.b043da6db7fb209437526be48d7a56b2.png
try in your own language as english is my primary an your may differ
:superman:superman
I use english as a system language. What version of Mojave you are running ? People from tonycraposx86 report that this manipulation doesn't work anymore with 10.14.2
im on 10.14.2 an is working in mine as i showed the pic, also i never believe anything from tonycrap :D
only system logo has a different way of editing
Added in 30 minutes :
try an edit en_gb folder an see
:superman:superman
[ref]ivandmpk[/ref], u can use in cpu type too
0x0a05
don't need mod nothing ;)
