I am getting thia KP on a freshh install.
It hangs around 2 minutes and then feeezes and KP
I7 9700k
GA Z390 Aorus Pro
HD630 graphics.
NVMe Samaung 970 Evo.
go back to high sierra your gpu is not going to work with mojave
:superman:superman
try with this clover https://Olarila.com/files/Clover.Folder/CLOVER.SERIES.100.200.300.zip
:superman:superman
I booted back from the SSD after the KP .. and it finishes the instalation ... Got another KP on setting up the account ... Now i booted back and it's working ... no internet no GPU but I will work this one out ;)
use the clover folder i posted an see if it helps
:superman:superman
ok when dsdt complete then see if issues
:superman:superman
I have disabled the C6 C8 or whatever states in the BIOS ...after loading the optimized defults and configuring the bios again the KP went away. Now my issue is only the graphic acceleration ... only 7MB aaand I think the USB 3.0 doesn't work.
:superman:superman
Say Hello to my new Graphics Card .
Sapphire Pulse RX 560 2 GB .
I put the card in the second PCIE slot next to my Nvidia . Did a clean install an everything works like a charm . Need to investigate on that USB 3.0 Problem ... with HDMI switcher i can switch to my nvidia 1070 Ti to use windows and game on it . :)
[ref]ivandmpk[/ref], if u need i can disable NVIDIA in OSX, and u use only AMD
[ref]ivandmpk[/ref], extract SEND_ME
[ref]ivandmpk[/ref], check there
Yes It does work my friend . I have 1070 Ti plugged in PCIE slot 1 and the AMD card in slot 2 .
You are the man !
Added in 17 seconds:
there it is
