[ref]nikhilrathore_1999[/ref], You are expected to find the EC method. This is something only you can provide. I advise you to read and follow the step by step guide again.
Donate
Gitter Chat
MSI B360 Gaming Arctic
My Laptop is HP and the hotkeys are F2 and F3. I did everything but my F2 and F3 keys have same code "_Q13". How can I fix this?
<IMGUR id="CosNBlw"><a href=https://i.imgur.com/CosNBlw.png' alt='IMGUR>'>
in ur case i think use HKNO
check it
into method label _Q13 replace_content
begin
Store(HKNO, Local0)\n
If (LEqual(Local0,7))\n
{\n
// Brightness Down\n
   Notify(\_SB.PCI0.LPCB.PS2K, 0x0405)\n
}\n
If (LEqual(Local0,8))\n
{\n
// Brightness Up\n
   Notify(\_SB.PCI0.LPCB.PS2K, 0x0406)\n
}\n
If (LEqual(Local0,4))\n
{\n
// Mirror toggle\n
   Notify(\_SB.PCI0.LPCB.PS2K, 0x046e)\n
}\n
end
check it
begin
{\n
}\n
{\n
// Brightness Up\n
}\n
{\n
// Mirror toggle\n
}\n
end
Thank you a lot, this worked very well :)
Yes! also good to check if ACPIDebug kext is loaded. I see unused EC method I can delete! :ugeek:
Dear @onemanosx, How could I get the DSDT file? Please help.
--Run_Me
RunMe.app
6 hours ago, Amin said:
console detects only the brightness up key (F12 as EC _Q66) but doesn't detect the down one , what then ?
dell notebooks have a different way
Hi, not being able to activate acpi debug on catalina. Any ideas how to make it work on catalina?
Thx in advance.
load kext via terminal
Quote
sudo chown -R root:wheel drag kext
sudo chmod -R 755 drag kext
sudo kextload drag kext
Thanks for answering,
but sorry, did not get it.
could you explain it (drag kext)?
regarding the unix commands, no problem.... :-)
Thx in advance!
sudo chown -R root:wheel ACPIDebug.kext
sudo chmod -R 755 ACPIDebug.kext
sudo kextload ACPIDebug.kext
sudo kextload -v ACPIDebug.kext
Requesting load of /Users/paulo/Downloads/Release/ACPIDebug.kext.
/Users/paulo/Downloads/Release/ACPIDebug.kext loaded successfully (or already loaded).
log show | grep -i acpidebug
nothing......
Hi.
Good Day
I have the catalina 10.15.3 version installed on the laptop asus ux501vw
All hardware is working properly only FN Key (Sleep (F1), WIFI (F2) ,Backlight (F3+F4) ,Brightness (F5+F6) ,Touchpad (F9)
asussmc.kext
lilu.kext
virtualsmc.kext
Thank you for helping me.
Well, i have almost everything working:
- hdmi audio, video, volume up/down keys, wifi/wired network, etc.....
only two items i'm not being able to make work or correct:
- screen flicker, when back from sleep or any unknown condition, where the only solution is a reboot
 and
- brightness keys.
ACPI debug not working.
Anyone with a good idea?
Catalina on a I5 skylake HP notebook 520 graphics.
