YES
fn+B and fn+s on working
You can switch to F11 and f12?
Please upload new sendme files with working FN+B and Fn+S buttons working DSDT
Donate
Gitter Chat
MSI B360 Gaming Arctic
Haunted me for a long time
Youcan tell me where the problem is?
Thanks thank you for your help me
Added in 7 minutes 24 seconds:
new send me file
Added in 9 minutes 48 seconds:
Excuse me
DeepSleep,Power button or keyboard Can not wakeup will restart
If you have any suggestions
Once again, thank for your support
Send me MTs-MacBook-Pro.zip
You can tell me where the problem is?
I am a little lost here. So are Fn+F11/F12 or F11/F12 now working?
Lets remove some errors in with ACPI I see in your kernel. Hopefully, by addressing these errors will make your laptop work better.
Try to reboot with these files and extract new sendme.
Archive.zip
Donate
Gitter Chat
[ref]mut0u[/ref], Check if Fn+11/12 works.
Can you also upload origin ACPI?
Donate
Gitter Chat
[ref]mut0u[/ref], I mean press F4 at clover bootloader. Then upload files in clover/acpi/origin.
Have you tried the last DSDT? Does the Fn keys work?
Donate
Gitter Chat
Does not work
Cannot enter when entering password
I am sure the password I entered is correct.
I think he should be a messy button
Added in 11 minutes 51 seconds:
fn+f11/f12 on working for this "3SSDTS"
MaLd0n said
Too many renames, so he gave me this DSDT.aml
Brightness adjustment only occurs at fn+s/b, not at f11/f12
3SSDTS.zip
Does not work
I see. I was trying to load up Rehabman's Dell Keyboard from his voodoops2controller. Seems it messes the other characters, too.
I have no idea what to do at this point.
However, please use this DSDT and upload new sendme. It wont solve your fn keys tho.
Donate
Gitter Chat
[ref]mut0u[/ref], add ECDV to EC renames
find: 45434456
replace: 45435F5F
There are some errors with track pad in kernel. But, I cannot suggest for change without looking at untouched origin DSDT.
Sorry for the long boot up time.
Here good working DSDT.
Donate
Gitter Chat
Hi
wake up from sleep issue
Have any suggestions
new sendme
Please open a new thread in forum.
Donate
Gitter Chat
hi [ref]onemanosx[/ref], i would like to try remapping my brightness hotkey. currently mw hotkey for brightness up is Fn+P and brightness down is Fn+C, and i plan to remap them to F11(down) F12(up).
my question is : which dsdt that i need to patch for acpi debug and remap key? is it the one from system or the one on ACPI/patched, since now i already have patched dsdt.aml from you on ACPI/Patched
thanks for your help
[ref]aryaone[/ref], use dsdt from acpi/patched. Remember to make a backup of the working DSDT
Donate
Gitter Chat
