but I'm still unable to map my brightness keys
Upon finding your EC method for brightness keys, did you proceed to the next step of patching DSDT?
Donate
Gitter Chat
MSI B360 Gaming Arctic
Hi [ref]onemanosx[/ref], I did patch my DSDT but forgot to edit _QD, QC :hammer ...now got my brightness keys mapped properly :cap , been looking for this kind of tutorial, hope you can make one for native power management cause my battery drains very fast, thank you for kind help, you guys are awesome! kudos to [ref]MaLd0n[/ref] as well :guitar:guitar:guitar
Congrats! You may check out Useful Links for power management guide and others
Donate
Gitter Chat
Sorry to bother you for the off topic again, but can you shed some light where should I start to make my battery works normal? one full charge only drains less half an hour :cry:
@onemanosx
Hi
After completing the guide I got EC Q66 and was F11 and F12,Have any suggestions
technically, you should have 2 EC methods. One for increase and another for decrease. I suggest you check your work again.
You can also paste the below code into terminal. The result will tell you which EC methods are being used.
log show | grep -i acpidebug
Donate
Gitter Chat
How do I upload an image?
use imgur
Upload your sendme files
Donate
Gitter Chat
[ref]mut0u[/ref], Please upload your EC method terminal image
Donate
Gitter Chat
sorry,
Please check
hxxps://www.insanelymac.com/forum/topic/336035-random-kernel-panic-on-shutdownreboot-and-nvram-problem/?page=8
mut0u is me my image
[ref]mut0u[/ref], Does press F11 and F12 only affect anything or Fn+B & Fn+S
Anyways, one more tryDSDT.aml.zip
Actually, there's 2 but lets try this first
Donate
Gitter Chat
[ref]mut0u[/ref], I just realised you enabled OSI to XOSI patch. That is not required. Disable it and try again with the DSDT.
Your SSDT has similar BRT6 patch.
Donate
Gitter Chat
