Administrators MaLd0n Posted June 2, 2021 Administrators Posted June 2, 2021 use acpi rename -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
مجهول الهوية Posted June 2, 2021 Posted June 2, 2021 1 hour ago, MaLd0n said: use acpi rename Can you give me a rename?
Administrators MaLd0n Posted June 8, 2021 Administrators Posted June 8, 2021 On 6/2/2021 at 11:07 AM, مجهول الهوية said: Can you give me a rename? u try with kext BrightnessKeys.kext? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
مجهول الهوية Posted June 8, 2021 Posted June 8, 2021 1 hour ago, MaLd0n said: u try with kext BrightnessKeys.kext? Yes and try rename BRT6 to XRT6 But doesn't work
Administrators MaLd0n Posted June 10, 2021 Administrators Posted June 10, 2021 just use terminal echo -n BRT6|xxd - 4252 5436 echo -n BRTX|xxd - 4252 5458 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
مجهول الهوية Posted June 10, 2021 Posted June 10, 2021 16 hours ago, MaLd0n said: just use terminal echo -n BRT6|xxd - 4252 5436 echo -n BRTX|xxd - 4252 5458 I am sorry for disturb you but -n option was not found And i am sorry for my english Problem Picture
Administrators MaLd0n Posted June 10, 2021 Administrators Posted June 10, 2021 55 minutes ago, مجهول الهوية said: I am sorry for disturb you but -n option was not found 4252 5436 and 4252 5458 is results -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
مجهول الهوية Posted June 10, 2021 Posted June 10, 2021 23 minutes ago, MaLd0n said: 4252 5436 and 4252 5458 is results Do you mean the switch from BRT6 to BRTX? I try this but doesn't work with or without brightnesskey.kext and i create brt6 ssdt but doesn't work thanks for your efforts
Administrators MaLd0n Posted June 10, 2021 Administrators Posted June 10, 2021 yes but only renames dont solve. u need renames and inject ssdt with brt6 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
مجهول الهوية Posted June 14, 2021 Posted June 14, 2021 (edited) On 6/10/2021 at 10:05 PM, MaLd0n said: yes but only renames dont solve. u need renames and inject ssdt with brt6 I am trying this SSDT's and this config but doesn't work Note with or without OSID rename doesn't work config.plist.zip ACPI.zip Edited June 14, 2021 by مجهول الهوية add file's
مجهول الهوية Posted June 15, 2021 Posted June 15, 2021 On 6/14/2021 at 4:51 PM, مجهول الهوية said: I am trying this SSDT's and this config but doesn't work Note with or without OSID rename doesn't work config.plist.zip 5.66 kB · 0 downloads ACPI.zip 4.47 kB · 0 downloads ??
Administrators MaLd0n Posted June 15, 2021 Administrators Posted June 15, 2021 17 minutes ago, مجهول الهوية said: ?? remove all acpi renames and post one full dump Post one Full Dump with Ioreg.https://www.olarila.com/topic/10301-olarila-runme-dumper/https://olarila.com/files/Utils/RunMe.app.ziphttps://olarila.com/files/Utils/IORegistryExplorer.app.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
مجهول الهوية Posted June 15, 2021 Posted June 15, 2021 38 minutes ago, MaLd0n said: remove all acpi renames and post one full dump Post one Full Dump with Ioreg.https://www.olarila.com/topic/10301-olarila-runme-dumper/https://olarila.com/files/Utils/RunMe.app.ziphttps://olarila.com/files/Utils/IORegistryExplorer.app.zip Thank you Full Dump
Administrators MaLd0n Posted June 15, 2021 Administrators Posted June 15, 2021 1 hour ago, مجهول الهوية said: Full Dump check if work DSDT.aml.zip dont need ssdts -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
مجهول الهوية Posted June 15, 2021 Posted June 15, 2021 41 minutes ago, MaLd0n said: check if work DSDT.aml.zip 46.89 kB · 2 downloads dont need ssdts Yes but Trouble video
Administrators MaLd0n Posted June 15, 2021 Administrators Posted June 15, 2021 what problem i dont see -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
مجهول الهوية Posted June 16, 2021 Posted June 16, 2021 16 hours ago, MaLd0n said: what problem i dont see 1 click 2 step
Administrators MaLd0n Posted June 16, 2021 Administrators Posted June 16, 2021 seems a bug check if have solution for that -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
مجهول الهوية Posted June 16, 2021 Posted June 16, 2021 2 minutes ago, MaLd0n said: seems a bug check if have solution for that Ok thanks
مجهول الهوية Posted June 16, 2021 Posted June 16, 2021 (edited) 2 hours ago, MaLd0n said: seems a bug check if have solution for that I am fix this after delete this Notify (\_SB.PCI0.LPCB.PS2K, 0x0286) //for increase brightness and this Notify (\_SB.PCI0.LPCB.PS2K, 0x0285)//for decrease brightness Edited June 16, 2021 by مجهول الهوية
